Home > Technical > Puma rear door latch lock
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
I have a new rear door latch for my 110 Puma Station Wagon. I want to swap over the long lock barrel but I can not figure out how to remove it from the old lock.
Any ideas? Is it even possible?
Post #1048348 11th Oct 2024 12:12pm
Shafski
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
?feature=shared
Hopefully this will sort you out.
I used this when I changed my on my Puma..
It can be done Thumbs Up Shafski
_________________________________________
2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E
Post #1048435 12th Oct 2024 7:49am
Rescue01
That’s weird I’ve just received my new lock as the outer handle snapped and I viewed that video two days ago Laughing
Post #1048451 12th Oct 2024 10:16am
Rescue01
Fitted my lock today. It took a bit of jiggling and some WD40 but it’s a easy enough job. Thumbs Up
Post #1048474 12th Oct 2024 4:24pm
Shafski
And I bet it felt gooooooodddd!
Thumbs Up Shafski
Post #1048475 12th Oct 2024 4:39pm
steveww
Thanks for the reply. I've already watched that video but both the old and new latch do not have a pin for the lock barrel. I'm a bit stuck at the moment.
Post #1048834 16th Oct 2024 9:43am
bodstruck
The vid shows the older style lock. The barrel can be changed on a puma lock, I did it on mine a few months ago. I'll try and dig out some more info but from memory the little hole is inside the latch casing on the puma rather than outside like the tdi one. It is fiddly but there is just about access. You need a fairly long pin.
My door is still of the wagon so I'll see if I can get a photo.
Post #1048850 16th Oct 2024 11:08am
Shafski
I did mine on the PUMA too, it can definitely be done. Shafski
Post #1048851 16th Oct 2024 11:11am
bodstruck
Can't get a decent photo, sorry. But this helped me do mine:
https://www.defender2.net/forum/post890567.html
Post #1048852 16th Oct 2024 11:12am
steveww
I took a good look at the new part and I can see the hole for the pin. Looks like a right PITA to get at. At least now I know what I'm aiming for.
Thanks for the help.
Post #1049045 18th Oct 2024 8:23am
