Home > General & Technical (L663) > Engine choice in a 90 which one would you choose (Pre loved) |
A1C6 Member Since: 15 Oct 2024 Location: Australia Posts: 54 |
The P400 is a really great engine in the 90, and definitely gives the car some 'oomph'. However, you will not be able to get the 18 inch steelies with that due to break size. The Diesel engines (D200, 250 and 300) obviously have varying levels of power, but great low-down torque (at least in the D300, don't know about the other ones) and really freaking long range. A D300 110 can do over 1100 km on a single tank on the highway.
15th Oct 2024 8:26am |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3406 |
Iโve had both D200 and D250 3.0, both are decent no complaints with pulling power of the D200. D250 though is more than enough for most tasks. 24MY 90 D250 HSE, Tasman Blue
15th Oct 2024 12:37pm |
CincyRovers1 Member Since: 30 Nov 2023 Location: Cincinnati, Ohio Posts: 84 |
Depends if you are getting a gas or diesel. The 2.0 and 3.0 gas engines are both excellent and have proved to be quite reliable. We don't get the diesels here in the US, but the 2.0 diesel that was used for the first model year is prone to turbocharger issues and oil dilution problems. the 3.0 diesel doesn't have these problems. ๐๐๐๐ ๐๐๐๐๐ง๐๐๐ซ ๐๐๐ ๐ ๐๐๐๐ (Pangea Green over Acorn/Lunar)
๐๐๐๐ ๐๐จ๐ซ๐ฌ๐๐ก๐ ๐๐๐๐๐ง ๐ (Dolomite Silver over Black/Bordeaux Red) ๐๐๐๐ ๐๐ข๐ฌ๐๐จ๐ฏ๐๐ซ๐ฒ ๐๐๐ ๐๐ฎ๐ฑ๐ฎ๐ซ๐ฒ ๐๐ข๐ (Aintree Green over Vintage Tan/Ebony) - Gone ๐๐๐๐ ๐๐๐ ๐๐๐ ๐.๐ (Ipanema Sand over Almond/Arabica) - Gone |
15th Oct 2024 12:54pm |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1399 |
You need a minimum of 6 cylinders.
I havd a D250 110 and it's pretty impressive. Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
15th Oct 2024 2:41pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2840 |
D250 is all you will ever need.
D300 is a bit more power if you see one but probably not worth paying a premium for. |
15th Oct 2024 2:51pm |
H1Tad Member Since: 20 Jul 2024 Location: Maine Posts: 130 |
The P400 is plenty peppy in our 110. Not the fastest but plenty of power to get around town. I imagine in a 90 it would be quite well. I will say that the 110 with the roof rack seems to struggle to get to 80mph. On most modern vehicles 80 is a stable cruising speed but on our 110 it seems like it just needs to be pushed to get there.
If mileage is also a concern, the P400 might not be the best choice. 2022 Defender 110 SE P400 Tasman Blue Expedition and Cold weather package 2003 Hummer H1 P400 Firehouse Red 2008 Toyota FJ Cruiser |
15th Oct 2024 4:12pm |
Crazymind Member Since: 11 Jun 2024 Location: Glasgow Posts: 156 |
D300 seems the right engine. Itโs good for everything does excel in nothing. This makes it for a superb workhorse of which youโll Never get tired of. 28 to 30mpg are achievable without any effort.
If petrol, I would go V8. Unless you do millions of miles per Year the consumption is not much worse than the other petrol options. |
15th Oct 2024 8:05pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2656 |
D200, D250 and D300 are all basically the same engine with different tunes. Any of them will be perfect. My 110 is a D200 and it has more power and torque then I can reasonably use.
15th Oct 2024 8:33pm |
True that! Not much difference in terms of torque between 200/250/300 and 350!
Itโs the medium punch that makes the difference. 300/350 they pull to the red line without losing any power. And they all burn the same amount of fuel. D200 and 250 have more torque at lower rpm, 1200 compared to 1500 of d300 and d350. Other than that if second Hand I d go for 250/300. Power is never enoughโฆ |
15th Oct 2024 8:39pm |
You can have the engine reconfigured to higher output levels using JLR's in-house Pathfinder software. So a D200 can be coded to a D350 just by changing the CCF files in the ECU. Since it is a factory tune, it will have no affect on the warranty. It can also easily be reconfigured to the original stock tune if you decide you don't like it. Companies like JLR Active can help you out, even though they're based here in the US. ๐๐๐๐ ๐๐๐๐๐ง๐๐๐ซ ๐๐๐ ๐ ๐๐๐๐ (Pangea Green over Acorn/Lunar)
15th Oct 2024 8:51pm |
I am not sure but I think I have read up to D300 injectors are the same. D350 has got different injectors?
15th Oct 2024 8:59pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3757 |
All interesting points,
The V8 is out (although I'm trying to justify it) its too pricey yet as this is just 'another' car to add to the fleet for running around. MPG not an issue but depreciation on that would I think still be huge. Interesting that the D200, 250, 300, 350 have the 'same' engine and as long as the 3.0 can be tuned. That gives me more options looking at the spec I would like rather than engine and spec. |
16th Oct 2024 7:50am |
Silb Member Since: 24 Apr 2024 Location: Hamburg Posts: 9 |
I read somewhere that D200 has an aux cooler "missing" compared to D250 and D300. Worth keeping in mind (or checking) if you plan to increase the power output.
16th Oct 2024 7:58am |
A couple of weeks ago I added a good table to the Defender Wikipedia page that could help you visualise this: https://en.wikipedia.org/wiki/Land_Rover_D...ailability |
16th Oct 2024 10:28am |
