![]() | Home > Technical > Seat bolts turning freely |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3522 ![]() ![]() ![]() |
Are you sure you have a nutplate and not a rivnut in the underside of the bolts? I do not know when the changeover from nutplate to rivnut was done.
If it is a rivnut, best try is to hold the rivnut with a gripper from the underside. Sorry, its not what you probably want to hear. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5853 ![]() ![]() |
What he said.
You will have threaded inserts set into the seat box, and the bolt threaded into that. You will need to grip the insert with something like mole grips, to stop it rotating and then undo bolt. |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2316 ![]() ![]() ![]() |
If it is a nut plate there and not a riv nut, then you'll need to get something underneath the bolt head to exert some upward pressure on the bolt whilst undoing it. A flat blade screwdriver if there is space or a flat scraper tapped in under the head if there isn't.
HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Zapo Member Since: 22 Feb 2023 Location: Basque Country Posts: 15 ![]() ![]() ![]() |
Hello, sorry for the late reply!
In the end it was indeed the plate holding the bolt that turned on itself (I'm not sure of the name in English, based on the LRworkshop diagrams, it seemed to be called nutplate). In the end, using the Dremel, I managed to cut off the head, slide my hand over and catch the plate below. I'd bent it trying to pierce the rivet, but I managed to get it straight again and put a rivet back in to re-attach it. I spent 2 days on it, but I won the battle. I had tried using pliers to hold the plate in place, but the space between the two batteries (which I admittedly had no desire to dismantle) was too small to get a good grip. |
Nice to hear you got it sorted even though you needed a bit of LR engineering. 👍🏻👍🏻
