![]() | Home > In Car Electronics > Spectre Spotlights |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Normally the switch allows the extra lights to work when main beam is operated.
Switch on + main beam on = spots on Switch off + main beam on = spots off Switch on + main beam off = spots off. That’s the norm with that switch. I’d also assume all seven should light at the same time. |
psglas Member Since: 20 Jun 2019 Location: Aviemore Posts: 18 ![]() ![]() ![]() |
Agreed, that's the logical configuration. I'll trace the wiring and see what's up.
On the spots, they are all like that so must have been don't deliberately. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
Alternatively perhaps they are all the same age, from the same batch, and failing at the same time in the same way. It would be very strange to have a light unit like that where it is intentional that only four out of seven light sources actually work, and it is hard to see how it could be related to legality. |
It's the same four leds on each spot that light up so it looks deliberate and not failures.
What make of light are they? I can't determine it from the photo.
Based on the labelling they are a variant of these.
https://nssclighting.com/products/off-road...ving-light I figured it out. I was always looking at the lights with the engine off. When you have the engine running and they're getting the full voltage from the alternator, all seven elements light up ![]() |
Odd, but at least you've solved the mystery.
