Home > Puma (Tdci) > Initial loss of power building up to shunting and stalling |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 512 |
Do you know or can you monitor your rail pressure while all this is happening...
It sounds fuel pump related to me but if your egr valve is sticking it would def cause running issues like loss of power.. I'd start with rail pressure and a leak off test on the injectors first.. |
5th Oct 2024 3:57pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20324 |
Probably EGR valve stuck open momentarily, that can throw out all sorts of readings, affect MAF clutch switch timing and things like that.
The nature of what you are experiencing does suggest VCV though. How old is the fuel filter? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
5th Oct 2024 4:16pm |
nickc Member Since: 10 Jun 2016 Location: North London Posts: 19 |
Thanks for the prompt responses - re: the fuel filter, I meant to say I also changed that with the prv and vcv.
Re: the rail pressure I think the BAS tool can do that - the challenge I have is the vehicle is at the garage so I can’t play around with it…l’ll suggest to them they check this though |
5th Oct 2024 4:26pm |
it can along with a few other sensor outputs that can be useful... but I would expect a garage scan tool to have as good capabilities anyway..
im not sure if you have reinstalled the map you mentioned, and im sure you did confirm with Peter what the map actually did and whether it prevents egr function ....the BAS tool will tell you whether the egr is been commanded or whether its shut.. |
5th Oct 2024 5:37pm |
Hi, the map has not been reinstalled as yet, Peter’s advise was to ensure the vehicle is fully sorted/ fixed before reinstalling it. To be honest I am not sure what the original map did - the previous owner said that it was installed for improved economy as he did a lot of motorway miles.
5th Oct 2024 6:03pm |
I think this is more likely VCV & PRV related, especially VCV, they are common to cause all sorts of problems even when new.
It’s not uncommon for a duff one out of the box, the EGR doesn’t really cause much problems expect MIL or if it’s stuck open. Have you had any contaminated fuel, there was some with some in supermarket fuel not long ago, as water in diesel will cause a lot of problems, and kills VCV’s. Blackwolf on here has described this before, and with mine in the past I feel I can vouch for exactly that, it occurred with mine after filling up at a certain fuel station. And I think the coincidence is real, with VCV failure and fuel contamination. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
5th Oct 2024 6:29pm |
I'm new to defenders compared to most on here and only really finding my way round the 2.2 I have..but there is a lot about failing vcv valves on thec2.4 as opposed to the 2.2..if it was only contaminated fuel /water I'm pretty sure that would have an equal effect on a 2.2 vcv..and the high pressure pump as well on either vehicle..
I was wondering if the low pressure transfare of fuel from tank to pump has more to do with it..could the vcv on the 2.4 suffer from lack of lubrication more often than the 2.2 which has an electric pump and primes the system well .. Just thoughts and observations from the reading I've done..🤔🙃 |
5th Oct 2024 7:24pm |
Obviously no other views on that🤔...or folk are just been kind and don't want to tell me I'm talking .🤣
Anyway another question while it's on my mind.. Is the vcv valve on the 2.4 a normally open or closed valve..Reading I've done suggested that systems with a relief valve on the rail (which the 2.4 engine has) quite often employed a normally open valve... not sure why and can't find the article now... I'm pretty sure the 2.2 valve would be normally closed and opens when powered.. |
6th Oct 2024 10:04am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17361 |
Remember that the 2.4 and 2.2 VCVs are utterly different in every respect. It is highly likely that Ford re-engineered the valve after the problems with the 2.4.
The 2.4 VCV has always been a problem with the Ford applications of the engine too, it is not just a Land-Rover thing. The first time I went to buy my first replacement (I'm now on about number four or five now after 15 years and 276k miles) the parts man at my local Ford dealer knew the part number from memory because he sold so many of them. The last time he tried to sell me a 2.2 VCV, because that has now taken over as the best-seller. My impression from how the 2.4 VCV behaves and especially how it behaves when it is failing is that it is a normally-restrictive valve controlled by a PWM signal from the ECM. I think we would hear of far more popped PRVs if it was normally-unrestrictive, and popped PRVs are relatively rare (although many seem to be replaced unnecessarily).
To be fair you posted your question at 20:24 on a Saturday and are lamenting the lack of relies at 11:04 the following morning. That isn't a big window of opportunity for people long to reply! |
6th Oct 2024 12:17pm |
Ahhh..a watch is something I gave up using when I retired..and that's a fair while back😳..but yes now you mention it its not long for answers..
None the less thanks for yours👍 I only know a little about my vcv which is 2.2 I'm wondering what you mean when you say its vastly different to the 2.4 valve.. In design , or operation?? Mine is as far as I can tell a negative duty cycle valve, and the duty cycle between tick over and wot at no load only increases by about 10%.. That's from scope traces but I'm not sure that would be an effective way of diagnosing a mechanically sticking valve, and that's what I've been thinking about..mine is I'm assuming in good order and working well (and hope it stays like that😂) but would be good to test a known dodgy one.. Perhaps a current trace rather than duty cycle might be more meaningful.. |
6th Oct 2024 3:19pm |
