Home > Faults & Fixes (L663) > L663, Information about the turbo.( UPDATE)
ruben
Spain
Does anyone know the purpose or function of that screw or plug that the turbo has in its front section? I ask because I notice that it is slightly stained with oil or soot, and… I think I should consult….or not… !!
thanks in advance
THIS
 Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE
Post #1047760 5th Oct 2024 2:49pm
ruben
Spain
I see a small residue, perhaps the origin of the previous one pushed by the wind from the fan? Coming out of this small rubber tube that connects this register with a kind of sensor... Can someone give me a clue as to what the hell that sensor is? It's very few kilometers for the love of God... I don't want to think about when this is 18 years old and 400,000 like my beloved D3.
Post #1049497 22nd Oct 2024 9:48pm
eno
Australia
It is not easy to tell from the pictures but could it be thread sealant for the fittings?
Can you wipe the pieces clean and see if it comes back?
Post #1049589 23rd Oct 2024 8:41pm
ruben
Spain
I will try, thanks ENO for your kind reply!!👍🏼 Defender 110 SE I6 D250 23MY
Post #1049593 23rd Oct 2024 8:54pm
o-ren-ishii
Netherlands
You can find/but the workplace manual online. Id say this should be described in there.
Post #1049613 24th Oct 2024 7:29am
ruben
Spain
Hi, please, do you know any links?thnks!! Defender 110 SE I6 D250 23MY
Post #1049615 24th Oct 2024 7:32am
o-ren-ishii
Netherlands
I send you pm
Post #1049616 24th Oct 2024 7:37am
ruben
Spain
thanks very much buddy!! Defender 110 SE I6 D250 23MY
Post #1049618 24th Oct 2024 8:30am
ruben
Spain
update …It is premature, they have to do some tests, but the dealer is considering changing the turbo under warranty, well really are “the turbos” since there are 2 in cascade… I don’t know very well the scope and and neither the complexity of such an intervention…but I hope that, if at the end is necessary, it is a good decision and that they are at a sufficient technical level… I am a bit scared in a car so new! scary days!! Defender 110 SE I6 D250 23MY
Post #1050121 28th Oct 2024 10:55pm
lightning
Mine has always had a very small leak from that joint. l've looked at three others and they all had the same trace of oil from there.
l've never done anything about it, l think allowing the dealer to take it apart will generate more issues.
Post #1050135 29th Oct 2024 7:52am
ruben
Spain
That is very valuable information, meaning that they could put in a new turbo, with the risk that this entails, and the same thing would still happen… it makes me think then, thank you very much for your contribution.👍🏼👍🏼👍🏼👍🏼👍🏼 Defender 110 SE I6 D250 23MY
Post #1050139 29th Oct 2024 8:18am
ruben
Spain
If anyone else is willing to take a look at their turbos I would be very grateful!! very ver gratefull!! Defender 110 SE I6 D250 23MY
Post #1050140 29th Oct 2024 8:21am
A1C6
Australia
If I get around to it I may look at mine... D300 have the same turbos, right?
Also, on r/Newdefender I read that one of the two most common problems is something to do with the turbo cooling pipe (the other is DRLs manufactured during COVID)
Post #1050154 29th Oct 2024 10:17am
ruben
Spain
I will be attentive! thank you very much! 👍🏼
The problem that the dealer poses is that the turbos are not dismantled, they are “simply” exchanged as a whole block…what a problem when the warranty is no longer available!! 🤬 Defender 110 SE I6 D250 23MY
Post #1050165 29th Oct 2024 11:00am
Gareth
Hi A1C6 What is this about drl’s manufactured in covid? I am about to send my car in for a new headlight because of failed drl, and have been told it will be chargeable. 9 months out of warranty. If anyone has had a goodwill gesture it would be good to know. Cheers 👍 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
1968 S2a 88 aka Bob
2014 Jaaaag F Type 3.0 Supercharged.
Post #1050229 29th Oct 2024 9:29pm
