- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Louis-C
Re: Preconditioning on full SoC drains the battery | |
ardevd wrote:I have an issue with my P400e. If I precondition the cabin while the car is connected to a charger and at 100% SoC the vehicle will fail to maintain the SoC and instead drains the battery. I can see the vehicle pulling 1-3 kW of power from the charger but that doesn’t seem to be enough.
Also, if I set a departure timer, preconditioning will fail if the vehicle is at 100% SoC, and show a message in the app saying that SoC is too low.
Anyone have similar experiences? My charger is 32A and typically outputs 7 kW when the car is charging.
I worked out why this was doing it on mine.
My charger has a pre set charging window of 11:30pm to 5:30am when I have cheap rate electric.
When I was asking the car to precondition at 8am, even though the car was plugged in, the car could not pull anything from the charger as it was not in the charging window. So it would use the battery
1st Nov 2024 10:28am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
