Home > Puma (Tdci) > Chassis Strut Bolt Type - dimensions |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7956 |
That holds the bulkhead on. M12 or m10 can't remember which. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
25th Sep 2024 10:26pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17285 |
M12 x 180 grade 8.8, LR part number is AYG500080 for the bolt.
25th Sep 2024 10:57pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 732 |
Available in Stainless from YRM if you fancy an "upgrade" 😊
26th Sep 2024 6:40am |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 995 |
Aren't these the ones that are normally rusted solid? So maybe you are lucky. I recommend every bolt in the frame to be greased or sprayed with Fluid Film or equivalent to avoid corrosion
26th Sep 2024 6:58am |
