Home > Puma (Tdci) > Chassis Strut Bolt Type - dimensions
roche1800
While I was crawling around changing the front prop for knocking, not completely cured so unsure if the root cause, I stumbled across a bolt with no nut.
It’s under the front bulkhead (front door hinges) on the front chassis strut/leg, what’s the name and the size of the nut and bolt.
Here are 2 pics
Post #1046817 25th Sep 2024 9:50pm
jst
That holds the bulkhead on. M12 or m10 can't remember which. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1046821 25th Sep 2024 10:26pm
M12 x 180 grade 8.8, LR part number is AYG500080 for the bolt.
Post #1046824 25th Sep 2024 10:57pm
rustandoil
Available in Stainless from YRM if you fancy an "upgrade" 😊
Post #1046836 26th Sep 2024 6:40am
TexasRover
Aren't these the ones that are normally rusted solid? So maybe you are lucky. I recommend every bolt in the frame to be greased or sprayed with Fluid Film or equivalent to avoid corrosion
Post #1046838 26th Sep 2024 6:58am
