![]() | Home > General & Technical (L663) > Hill descent control without ATPC |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3428 ![]() ![]() |
You can set a speed for HDC, then it wonโt exceed that speed going downhill. ATPC is more like an off road cruise control where you set a speed and it will drive along at that speed without you using the throttle. 24MY 90 D250 HSE, Tasman Blue
CincyRovers1 Member Since: 30 Nov 2023 Location: Cincinnati, Ohio Posts: 112 ![]() ![]() |
Yes, HDC is standard on all LR products. Hell, it even came standard on my Porsche Macan. ATPC, is basically an off-road cruise control just as it was mentioned above. I have it on mine, but I don't use it that much. ๐๐๐๐ ๐๐๐๐๐ง๐๐๐ซ ๐๐๐ ๐ ๐๐๐๐ (Pangea Green over Acorn/Lunar)
๐๐๐๐ ๐๐จ๐ซ๐ฌ๐๐ก๐ ๐๐๐๐๐ง ๐ (Dolomite Silver over Black/Bordeaux Red) ๐๐๐๐ ๐๐ข๐ฌ๐๐จ๐ฏ๐๐ซ๐ฒ ๐๐๐ ๐๐ฎ๐ฑ๐ฎ๐ซ๐ฒ ๐๐ข๐ (Aintree Green over Vintage Tan/Ebony) - Gone ๐๐๐๐ ๐๐๐ ๐๐๐ ๐.๐ (Ipanema Sand over Almond/Arabica) - Gone Last edited by CincyRovers1 on 17th Sep 2024 3:59pm. Edited 1 time in total |
DrRob Member Since: 29 Mar 2017 Location: Hampshire Posts: 231 ![]() ![]() |
Yes. I have the same vehicle and HDC is standard. I didnโt opt for APTC. Not needed for most users. MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie" Many Range Rovers and Land Rovers over the years ๐ 1949 80" - still in family since 1975 |
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 516 ![]() |
Yep, I was using it last week in wales and it was very useful (I don't have ATPC) - Braking each wheel independently, depending on levels of grip, and being able to speed it up for smoother sections and slow it down for bumpier obstacles.
[removed incorrect info! Thanks Cincy] Last edited by XplusYplusZ on 25th Sep 2024 8:16am. Edited 2 times in total |
That is not how ATPC works. What you are describing is Terrain Response 2 or more commonly known as Auto Terrain Response. ATPC is an off-road cruise control that works between 1-18mph. You set the desired speed using the cruise control buttons to set a constant, steady speed and you won't need to focus on throttle application, just steering and analyzing your surroundings. TR2 is a reactive system that automatically adjusts the ABS, traction control, ESP, suspension, steering, throttle response and differentials depending on the type of terrain you are traversing. It does work incredibly well, but it is a reactive system, so it takes a moment (about 10-20 feet) for the car to figure out what it is driving over. The standard Terrain Response is a proactive system, so if you know what terrain you are on, you manually select the appropriate setting. I have TR2 on my Defender, but I only use it on-road, where it is excellent at adapting to road conditions. ๐๐๐๐ ๐๐๐๐๐ง๐๐๐ซ ๐๐๐ ๐ ๐๐๐๐ (Pangea Green over Acorn/Lunar) ๐๐๐๐ ๐๐จ๐ซ๐ฌ๐๐ก๐ ๐๐๐๐๐ง ๐ (Dolomite Silver over Black/Bordeaux Red) ๐๐๐๐ ๐๐ข๐ฌ๐๐จ๐ฏ๐๐ซ๐ฒ ๐๐๐ ๐๐ฎ๐ฑ๐ฎ๐ซ๐ฒ ๐๐ข๐ (Aintree Green over Vintage Tan/Ebony) - Gone ๐๐๐๐ ๐๐๐ ๐๐๐ ๐.๐ (Ipanema Sand over Almond/Arabica) - Gone |
My apologies, you're absolutely right. I forgot that function even existed as I struggle to think of a real world application for it.. when are you offroad and so distracted you can't use your foot to pedal?
Perhaps a Kenyan gamekeeper!? Or very long boring lanes? |
