Home > Technical > Air Intakes
jst
Air Intakes
I know the subject of air intakes has been covered lots of times.
However, i would still welcome views with the aim of getting more air into the engine for my setup.
I currently have a Nugget wing air intake adaptor connected to the std side intake. pipe (90mm) goes from this to the to the filter housing on the side of the engine. (m57)
what i am interested in knowing if there is much difference to air flow to justify the cost of changing between what i have
the Nugget wing adaptor box to std LR wing grill with 90mm pipe
to
1. Pipe straight onto side exit grill so do away with Nugget box - does it have a CSA constriction at the rectangular part?
2. a 4" pipe straight to wing side vent (not sure this is available off the shelf)
3. Fitting a large bore snorkel such as the Nakatanenga one with pre fitler at the top [url]https://www.4x4overlander.com/product/defender-raised-air-intake-defender-td4/ [/url]
i get it that option 3 gives me wading capability, i am not too concerned on this, but does it draw colder/'better' air?
or any other options? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1045857 15th Sep 2024 12:27pm
andy63
Well I've been commenting on the subject on and off and recently expressed my views on the alisport system I fitted after eventually finding the time to do and complete a few tests.., and whilst you will have a different engine and set up I'll make a couple general points you may want to consider..
You say get more air into your engine..my question would be more air than what..have you or do you monitor the intake air at present??
On the question of ducting..you need to try and establish whether your present set up is supplying your current engine needs (over its operating range) without been a restriction..again we are back to the point of needing to know what is actually flowing and maybe disconnecting it briefly from the air box to see if you get more air than with the ducting connected..if its adequate and doesn't affect the figures then there is little to be gained by increasing capacity unless you say intend say upgrading the turbo....
Those would be my first thoughts on the subject 👍
Post #1045877 15th Sep 2024 3:58pm
jst
I can't currently.measure.air intake vol but I belive it needs more air! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1045896 15th Sep 2024 8:37pm
Redlinemike
Scotland 2004 Defender 110 Other XS DCPU Auto Bonatti Grey
I have recently went to a 4" snorkel which is 4" all the way to the airbox where it steps down to 3.5",
 110 XS DC M57 + 8 Speed auto
ORA jeep- Sold
Tomcat 88
Post #1045901 16th Sep 2024 1:02am
jst
ok, so same engine. And???? any difference. before you had what 3.5 to that converted wing grill? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1045922 16th Sep 2024 10:09am
jst
that noisy?
nice plate. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1045923 16th Sep 2024 10:11am
Redlinemike
Induction noise isn't much different other than it sounds cooler, so far have found it to make a difference in regards to the general smoke under load , it's gotten better from a haze to a wisp is probably the best way to describe it when working it hard 110 XS DC M57 + 8 Speed auto
ORA jeep- Sold
Tomcat 88
Post #1045951 16th Sep 2024 7:14pm
