Home > Off Topic > APPLE Expert required |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1027 |
This. In other terms, Walfy, the software that you use to remote login to the client‘s system is just an application like any of your other Mac applications. Any software can have one or many multiple floating windows which you can place anywhere. Or you can make a window „fullscreen“ - on a mac this has some properties that Windows don‘t - read about „Mission Control“ on macOS.
Anway, as said, to achieve what you want you‘ll need to check what‘s possible with the macOS application you use to login to the remote system. The remote system has nothing to do with it. For example I use VMWare Horizon to login to a client‘s Window‘s PC (ugly.. ) I can make VMware use a window (a macOS one) and move that to any screen I want. I can select „fullscreen“ in VMWare‘s mac (!) menu bar to make that window fill one screen. Now, in that mode VMWare has another setting where you can choose how many and which of the Mac‘s screens it should use. So I could have eg the remote Windows on two screens and my Mac desktop on one. THEN I may have to tell the remote Windows PC which screen is physically placed where. See above. Although I noticed with VMWare it seems to forward my Mac settings to the remote Windows. it’s much simpler than it sounds |
11th Sep 2024 7:45pm |
jonny Member Since: 10 Mar 2013 Location: North Wilts Posts: 145 |
Open up Microsoft Remote Desktop.
Go to the saved session that you connect to. Right click, edit (or click the pen icon). Select Display. Check the 'Use all monitors' option. When you connect in full screen mode, it will use all the displays connected to the Mac. |
12th Sep 2024 12:24pm |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1022 |
Take a look at Royal TS for your RDP connections. I use the Windows version but available for Apple too.
Free version is only limited by the number of connections you can save. Much easier than fighting with a standalone RDP client and has all the multi-monitor stuff in the connection. |
13th Sep 2024 6:51am |
