Home > In Car Electronics (L663) > reverse camera
sasa
Czech Republic
reverse camera
hello, today my back camera stopped work, i tryied reset pivi several times (Powerful has the same problem), but no fixed. Any idea please?
is it possible to fix it throught the G4 for example, and how? thank you
Post #1042306 9th Aug 2024 11:50am
Philm
Mine also failed, the only fix was a new camera. Big Cry
Post #1042309 9th Aug 2024 12:28pm
sasa
Czech Republic
hello, from Gap team support i got this - does anyone help how proceed? I am begginer
B12BD-96 Rear Camera - Component internal failure
Rear proximity camera internal failure
NOTE:
DO NOT replace the near field sensing module for this DTC
Using the Jaguar Land Rover approved diagnostic equipment inspect the status bits for this DTC on the DTC information page. For this DTC, any one of the following combination status bits need to be set for the DTC to be valid (for example, there is a "Yes" against all of the status bits listed below)
Test Failed (Bit 0)
Test Failed This Operation Cycle (Bit 1)
or
Confirmed DTC (Bit 3)
If none of the above combinations are valid ignore this DTC (the customer may not have experienced non-operation of the near field sensing system features)
If the DTC is valid (any one of the combinations is true) follow the instructions below
Using the Jaguar Land Rover approved diagnostic equipment, clear the Diagnostic Trouble Code(s) and retest
If the fault persists, install a new rear proximity camera
Post #1042371 10th Aug 2024 7:43am
sasa
Czech Republic
it's strange, yesterday the camera started working by itself ( first i deleted the errors but that didn't help)...
on the one hand I'm happy, on the other
I'm more worried about when it will happen again in the future when the car is no longer under warranty
Post #1042470 11th Aug 2024 9:20am
sasa
Czech Republic
hello, I noticed that the parking camera stops working after a few days after I restart the park assist (it works great, the car parks itself, without problems). Does the person for whom the park assist works also have the rear camera working after a few days?
Post #1045622 12th Sep 2024 11:33am
sasa
Czech Republic
Solved - new camera Very Happy Very Happy Very Happy
Post #1051819 15th Nov 2024 11:37am
