![]() | Home > In Car Electronics (L663) > reverse camera |
Philm Member Since: 19 Jun 2020 Location: Manchester Posts: 177 ![]() ![]() |
Mine also failed, the only fix was a new camera.
sasa Member Since: 05 Mar 2024 Location: ceska lipa Posts: 60 ![]() ![]() |
hello, from Gap team support i got this - does anyone help how proceed? I am begginer
B12BD-96 Rear Camera - Component internal failure Rear proximity camera internal failure NOTE: DO NOT replace the near field sensing module for this DTC Using the Jaguar Land Rover approved diagnostic equipment inspect the status bits for this DTC on the DTC information page. For this DTC, any one of the following combination status bits need to be set for the DTC to be valid (for example, there is a "Yes" against all of the status bits listed below) Test Failed (Bit 0) Test Failed This Operation Cycle (Bit 1) or Confirmed DTC (Bit 3) If none of the above combinations are valid ignore this DTC (the customer may not have experienced non-operation of the near field sensing system features) If the DTC is valid (any one of the combinations is true) follow the instructions below Using the Jaguar Land Rover approved diagnostic equipment, clear the Diagnostic Trouble Code(s) and retest If the fault persists, install a new rear proximity camera |
it's strange, yesterday the camera started working by itself ( first i deleted the errors but that didn't help)...
on the one hand I'm happy, on the other I'm more worried about when it will happen again in the future when the car is no longer under warranty |
hello, I noticed that the parking camera stops working after a few days after I restart the park assist (it works great, the car parks itself, without problems). Does the person for whom the park assist works also have the rear camera working after a few days?
Solved - new camera
