![]() | Home > Technical > Defender not starting after fuel injection pump installation |
Ary Member Since: 31 Aug 2011 Location: rua Amapa 1651 P. Alegre Posts: 2 ![]() ![]() ![]() |
Hi
Try to connetc it to the solenoid valve at the top of the injection pump. Ary Defender 110 |
cecilkift Member Since: 19 Jul 2024 Location: California Posts: 6 ![]() ![]() |
Thanks for the response, I already have a plug connected to it, and if the ignition is on and I pull it in and out i can hear the solenoid click
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 681 ![]() ![]() |
Hi..I was going to say exactly as has been said as the lead does look fuel pump solenoid 🤣 Given that it's not and the work you mention doing is it possible that the fuel pump has been timed incorrectly relative to the valve timing..you do seem to have covered all the obvious .. It happened to me many years ago.. I couldn't get my car started after some work and it wasn't till I removed the valve cover that I noticed the spark was going to no 1 but the valves were open..🙄🤣 |
Thank you. I guess I will have to study some more and see how to time those two.
Loving the process of figuring out how to make this Rover run again. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8204 ![]() ![]() ![]() |
Feed and return lines on the right way?
When it cranks over what comes out the exhaust? Why did you change FiP? Diaphragm pin is free to move? Fuel delivery pin contacting Diaphragm pin correctly Did you purchase a complete reconditioned pump or have you added parts to it? Assuming physically fitted correctly and above works then look back at timing but sounds like you have checked all that already. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
giles Member Since: 21 Jan 2013 Location: 81600 Posts: 9 ![]() ![]() |
Hi, Is it possible that the solenoid wire is the wrong one, i.e, power on when it should power off (or vice versa). Might explain the click but no start. Have you got diesel at the injectors?... |
