Home > Maintenance & Modifications > Swivels |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8148 |
I use cv grease straight out of grease gun. It's easier and cheaper. You can work out amount needed.
Warm sachet in water if your going to use them, turn steering to lock to open up hole. How you getting the old grease out. And if its not contaminated, why? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
9th Sep 2024 8:58pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 743 |
Just curious, my swivel seals need replacement and I needed to top off the grease here. Using the rated grease as per manual, any disadvantages to filling to the brim? No Better Friend, No Worse Enemy
11th Sep 2024 8:40am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20571 |
They are a supposed to be 330 - 350ml max each, I don’t think you can reliably tell how much is in there even when dipping with a zip tie or something similar, but you can tell if the swivels get dry, leak or become scored visually externally. If greased then leaking isn’t quite so much of an issue like oil would be on previous generations.
It’s when these things get dry, the grease drys up and significant wear happens rapidly so, that’s why I prefer a little top up of greases often. I don’t think you can clear it out really, without a full dismantle, and contamination luckily isn’t an issue. The CV’s and swivels are parts I have never had to touch before, regards the swivels, what is the purpose of the shims? Presumably minor adjustment KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
11th Sep 2024 8:54am |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 763 |
The shims are vitality important to the swivel housing pre-load......lots of stuff about that job on here
11th Sep 2024 8:58am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3467 |
Just keep in mind that even though you do not see external leaks on the swivels, the grease might migrate into the diff housing. You can tell if that is happening when the diff oil is darker than normal. Its not an issue for the diff, a bit of molybdenum is good for the gears, perhaps less so for the bearings, but is an issue for the CV is not enough grease remains. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
11th Sep 2024 9:58am |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 497 |
You’ve got to set the preload with the shims, or it will shake and drive you nuts! If yuk is coming out then there’s yuk in. If there’s no yuk then either it’s sealed beautifully or it’s got no yuk in. My swivels are most probably the original chrome ones and still good, even though it sat for 15 years.
11th Sep 2024 4:34pm |
