Home > Maintenance & Modifications > New propshaft
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
New propshaft
I’m just after views and opinions. I need to replace the front UJ’s in my 110. I can do it myself ( but don’t like the job ) but a brand new one is £113 delivered. Is it worth the effort to renew the three joints myself - it’s a Disco 2 prop- or just stick the whole thing on? In an ideal world I’d fit one of Gwyn Lewis’s, but I haven’t got the funds for that right now. I’m not convinced that genuine would be any better as my new old stock genuine rear prop needs joints at not even 20k, surely the cheap one won’t be any worse? Or will it….
Post #1045438 10th Sep 2024 5:00pm
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
If its a D2 front double cardan joint there is also a bearing in the middle of the two UJs at the transfer box end. If this is the case you can rebuild them and they last a while but its quite a fiddly job extracting and replacing the centring bearing and if done wrong they can self destruct spectacularly. Having rebuilt several of these with GKN UJs they tend to do another few years before starting to deteriorate and the whole process you might aswell replace with a new one. 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1045442 10th Sep 2024 5:22pm
I’d only look at GKN UJ’s or new props, anything else isn’t worthwhile.
I put GKN ones in mine and they have been perfect since, I lube them every 3 months.
The only issue is a new prop will be 100% balanced, whatever you do replacing the UJ’s there is probably a little imbalance but I’ve not found that to be any issue.
Just so long as everything goes back in, exactly as it was taken out, just with new UJ’s fitted.
Then it’ll be fine. WeWillWin🇬🇧🇺🇸
Post #1045443 10th Sep 2024 5:27pm
MarkBrown
That’s what I’m thinking. Yea it’s a DC prop. I’ve done them before, it’s a right fiddle. The boot has perished also. The GKN ones don’t last that long either then?
Post #1045444 10th Sep 2024 5:30pm
GKN are good, wouldn’t bother with anything else. WeWillWin🇬🇧🇺🇸
Post #1045446 10th Sep 2024 5:33pm
34064
I mean it really depends but i have rebuilt quite a few now For discoveries which i have had and they will last a few years but i tend to find its the centring bearing fails more than the UJs possibly as mentioned above about the balancing 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Post #1045447 10th Sep 2024 5:34pm
BrickBox
Might be worth just finding good condition used ones off eBay from a company like LRParts or someone similar - they’re cheap enough and then you can referbish yours in your own time. Handy having spare ones kicking about. 2008 2.4 110 Utility Station Wagon XS.
Post #1045449 10th Sep 2024 5:52pm
Standard props are Hardy Spicer I think. WeWillWin🇬🇧🇺🇸
Post #1045456 10th Sep 2024 6:19pm
The centering bearing used to be quite hard to obtain, I had to get some from the USA last time I did this job. As noted above replacing the UJs and bearing at the DC end is very fiddly, much trickier than just doing a single.UJ.
My policy is that if the splines are perfect I'll overhaul the joints, if the splines are in the slightest bit worn replace the shaft.
If you really want a fun experience, try changing all the joints and bearing on a Gwyn Lewis HD DC shaft. It's a complete nightmare due to the huge size of the UJs!
Post #1045468 10th Sep 2024 8:02pm
