Home > General & Technical (L663) > Gap Diagnostic Tool working Activations
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I have tried to collate all the known working settings into this post, if anybody spots a mistake or has an addition to make just shout Thumbs Up
Please don't reply to this post, lets keep this for the working list only, The main thread is here https://www.defender2.net/forum/topic85281.html
- Activate WIFI/WLAN Hotspot
MultiCAN-814 IVIWiFiHotspot
Standard: Not fitted
Changed to: Internal WiFi Hotspot fitted
- Change Splash Screen to "Defender 007"
EUCD-205 Racing Sub Brand
Standard: Mainstream Vehicle
Changed to: LTD 007
- Dynamic Mode
EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode"
EUCD-245 Dynamic-I
Standard: Dynamic-i Not Fitted
Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen
MultiCAN-562 DynamicProgMode
Standard: Not available for selection
Changed to: Available for selection without timeout
Other possible value: Available for selection with timeout
MultiCAN-605 ConfigDynamicMode
Standard: Not Fitted
Changed to: Fitted
MultiCAN-777 Ter Dyn Select In FCPB
Standard: Control interface not available in FCPB
Changed to: Rotary used for selection within touch screen
-Remember Stop/start setting
MultiCAN-566
MHLastUserMode = Enabled
For Walk away locking and Approach unlocking the general rule is that it is only available on MY2023 onward, if you don’t have a locking fuel cap you can enable both. You will also have to go into your centre screen setting and switch it on. Some people with earlier cars have got this to work but it is a bit of a lottery Confused
-WalkAwayLocking
MultiCAN-505
Change it to Current: Enabled
-Approach unlocking
MultiCAN-807 Approach Unlocking
Disabled
Change to Enabled
-Modify signature LEDs behavior
MultiCAN-463 DRLBehWhilstDIsAct
Current: Turn Off
New: No Action
MultiCAN-465 DRLBehWhHazardsAct
Current: Turn Off
New: No Action
This setting is to keep them on while the turn signals or hazard lights are operating.
- The subwoofer was installed in the base model, but wasn't enabled.
EUCD-121 Subwoofer
Standard: Without Subwoofer
Changed to: Subwoofer
-Enable All Microphones
EUCD-126 Microphone = Four Microphones (Two Front & Two Rear)
Standard: Microphone (Driver Only)
- Disable Seatbelt Reminder
MultiCAN-717 Front Belt Minder
Beltminder Fully OFF
MultiCAN-737 Rear Belt Minder
Rear Beltminder OFF
- MultiCAN-770 Remote Release Tailgate
Enabled
This will make the rear door pop open when you press the button on the key fob
-MultiCAN-723 Gloabal open/close
MultiCAN 723 SMRF Global Close - changed to Enabled
MulitCAN 719 CDL Global Close - changed to Enabled
MultiCAN 719 CDL Global Open - changed to Enabled
EUCD 184 Global Open/Close - changed to Global Open/Close Doors + Sunroof
- Configurable TR
MultiCAN-736 Config TR Fitment - Not Configured > change to Off Road Configuration
MultiCAN-755 Config TR Mode - Not available for selection > Change to Available for selection with timeout
MultiCAN-797 Ter CT Select In FCPB
> Change to Rotary used for selection within touch screen
- Disable drive away locking
MultiCAN-740 Drive Away Door Lock to Disabled - To disable drive away locking
- Foglight with HighBeam
EUCD-018 Foglight Function
Foglight without restrictions
MultiCAN-734 Front Fog Lights Oft High Beam.
Set to Disable.
- More accurate speed reading
MultiCAN-838 from: Speedo market 0- 3.5% + 2kph
To Speedo market 1- 2.0% + 0kph
- Tow Assist2
MultiCAN-579 Tow Assist
Set to Tow Assist 2
MultiCAN-635 Towing
Set to Not Support if not already set to this setting.
MultiCAN-696 ATCM TA2 Switch
Set to Tow Assist 2 feature selection switch not fitted, again if not already set to this.
MultiCAN-793 TA2 Input Control
Set to HVAC rotary.
MultiCAN-795 TA2 Select in FCPB
Set to Rotary used for selection within touch screen.
- After retrofitting 11.4" display
MultiCAN-641 FrntUpperDispVariant
Alpine 11.6 inch Single View
Clarke4x4's thread on fitting larger screen
https://www.defender2.net/forum/topic89297.html
- After retrofitting ClearSight Interior Rear View Mirror
MultiCAN-711 Interior Mirror Variant
IRVM
changed to SVRM
Marco's thread on fitting Clearsight Mirror
https://www.defender2.net/forum/topic88338.html
- To turn off DRL / signature LEDs, aka "halos" in premium / matrix type headlamps:
MultiCAN-468 FntDRLType
Current: Incorporated DRL and Pos
New: No DRL
- To turn off Autohold Permanently
MultiCAN-711 Auto Hold
Current: HVH Enabled
New: HVH Disabled
- ACC Adaptive Cruise Control Requires IID Tool G4 to activate
MultiCAN-580 PTCruiseFitment: ACC with Queue Assist fitted
MultiCAN-712 ACC Lead Car Distance Display: Fitted
MultiCAN-809 ACC Stop Gap Setting: Fitted
All terrain progress control (ATPC) Requires IID Tool G4 to activate
MultiCAN-476 ATPC
Original: HDC Change to : HDC and LSPC
Stop Driver assistance resets to High
MultiCAN-889 GSR2 EU Market Ft
Change it to Non GSR2 Country
Configurable Terrain Response (TR2) Requires IID Tool G4 to activate
MultiCAN-755 Config TR Mode - Not available for selection > change to Available for selection with timeout
MultiCAN-797 Ter CT Select In FCPB Change to "Rotary used for selection within touch screen
A couple of videos that should help new users
How to enable the James Bond Screen
How to email a copy of your CCF File to yourself
 Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1006773 6th Sep 2023 9:27pm
mmbanf
Italy
Thanks Ian for the work, very helpful. Thumbs Up
Marco
Post #1006785 7th Sep 2023 6:26am
mani_jeenu
Australia
Others I found in the forums while reading
Set to Disable.
Tow Assist2
Set to Tow Assist 2
MultiCAN-635 Towing
Set to HVAC rotary.
IRVM
changed to SVRM
Post #1006865 8th Sep 2023 5:02am
Mark1107
United States
Ok, to camp or greenlaning,
We sleep in the back on camping trips. I disabled the vehicle waking up and the lights coming on or off with solely the tailgate/boot door opening and closing. Now for my regular contributions to the forums:
Multican 703 “BCM interior light trunk” Fitted.
Multican 703 BCMinterior light delay” Fitted. Immediately turns out all vehicle lights without a 30 second delay.
So the 1st one stops ALL vehicle lights when trunk/boot door is opened or shut.
The 2nd one immediately stops the lights when any of the 4 passenger doors are opened because our vehicles are set for a 30 second delay which drains the battery. 2022 Defender Trek Competition 110 collectors edition!
2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold)
2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair
2014 Range Rover L405 Autobiography Full Size Aintree Green
2014 Dodge Viper GTS Stryker Green
Post #1033918 5th May 2024 11:28pm
TSY
... a couple more that I didn't see above that I have adjusted. (MY24 110 P400)
____________________________
Wiper Drip Feature
MultiCAN-726 Wiper Drip Wipe Feature
Change to:Disabled
Turn puddle lights off (if you're not a fan of the "graphics")
EUCD-087 Puddle Light
Stock setting: Outer Mirrors With Puddle Light (0x2)
Change to: Without puddle light
Disable the fake engine noises played through the stereo (or choose different versions) with these two settings: (I highly recommend disabling this on long roadtrips... it's more present than you think.)
Next Generation Power Train Sound Quality (NGPTSQ)
MultiCAN-584 NextGenPwrTrnSQ
Select: Not Fitted
MultiCAN-585 ActSndDesignPwrlvl
Not Supported
Select: Not Fitted
* Both set to ' Not fitted ' for off
Post #1045365 9th Sep 2024 9:32pm
Sticks999
Hi has anyone managed to get park assist to work. I have entered all of the below and everthing is present but the Start button is greyed out.
Park assist settings
Activate Park Assist
EUCD-059 Parking Assistance
Standard: Without Parking Assistance
Change to: PDC (Front, Rear) - Parking (Parallel, Exit)
EUCD-099 Park Assist Camera
Standard: Without Park Assist Camera
Change to: With Park Assist Camera
EUCD-140 Pdcautoactivationmenu
Standard: Not supported
Change to: With PDC Auto Activation menu
MultiCAN-469 PDCAutoActivation
Standard: Not Supported
Change to: Default OFF configurable
MultiCAN-500 PDCBtnFCIM
Change to: Fitted
MultiCAN-602 PDC
Standard: PDC not fitted
Change to: 10 Channel fitted ( Park Assist)
MultiCAN-786 Park Assist
Change to: Full Auto VarD (Fully automated park assist with automated steering breaking acceleration and gears)
• Needed 2 resets to PIVI for the app to appear in PIVI and a full car shut-down to clear the "Emergency Brake Assist Unavailable" error.
Post #1045405 10th Sep 2024 10:50am
cfong02
Malaysia 2014 Defender 110 Puma 2.2 DCPU Zermatt Silver
Comparing with a working vechile
HI,
I am also struggling on the Defender, grey out 'Start' button during auto parking.
I have an L460 Range Rover with full specs and park assist; I to share my settings here:
Standard: Default OFF configurable
MultiCAN-602 PDC
Standard: 10 Channel fitted ( Park Assist)
Standard: Full Auto VarD (Fully automated park assist with automated steering breaking acceleration and gears)
You will notice that many Defender CCF settings were NOT enabled on my Range Rover, even though the Range Rover has full park assist. So I assumed we are looking at the wrong parameters in the Defender CCF?
ALSO, The last user memory in Defender (MultiCAN-566 MHLastUserMode) is not working on the Range Rover, I still have to manually turn off Auto Start/Stop
Post #1046357 21st Sep 2024 5:54am
Metisse
Park assist working.
I have a 2022 Defender 110 p400e Hybrid and a GAP IID Gen 4 tool.
I made all the changes to the CCF to Activate Park Assist as described by many others here and after a few days noticed that the park assist icons were now available. Blue square on lower right of the instrument panel and additional park assist icon on Pivi Pro screen.
I decided to have a play in an empty car park and noticed that the Start button did illuminate briefly but then greyed out. I use the auto hold and noticed that as soon as I took my foot off the brake the start button greyed out. It seems you have to keep the footbrake pressed to keep it illuminated. I then touched the Start button and after a brief delay it activated and said to release the brake pedal. The appropriate indicator came on and the vehicle completed the parking manoeuvre.
It's not something I would generally use and occasionally it has braked very sharply at the end of the manoeuvre so it may not be as refined as Land Rover would like although other models do have the instructions on their online iGuide. (e.g. New Range Rover Sport https://www.ownerinfo.landrover.com/docume...2/G3308667 )
Not sure if this will make any difference but worth having a go.
Peter 2022 Defender 110 HSE P400e Tasman Blue
Post #1046809 25th Sep 2024 6:36pm
cfong02
Based on what you have described, this is how the auto park assist works. You need to press the Break while pressing the Start Button.
Could you please share your complete CCF? I'd love to have a 1-to-1 comparison with mine
2023 - P300, 110
Post #1046994 27th Sep 2024 4:11pm
Metisse
I've uploaded a text dump of my CCF and added it to my gallery so you can access it without me clogging up the thread.
Regards
Post #1047025 27th Sep 2024 7:57pm
cfong02
Thank you !
I have put together a comparison between mine and yours.
The comparison document is now in my gallery as well
FULL CCF - https://www.defender2.net/gallery/albums/u...ompare.pdf
Differences Only CCF - https://www.defender2.net/gallery/albums/u...2BDiff.pdf
During my initial walk-through, I noticed that the glaring differences could be TOW ASSIST (?)
I'll still spend some time exploring.
Post #1047050 28th Sep 2024 4:26am
Metisse
Many thanks for the comparison file I will go through it in some detail later. I changed the CCF for the Tow Assist as it didn't come with that enabled but I have yet to get that to work, so I don't think that will affect the park assist.
I have made some other changes (seat belt, speedo accuracy etc) but having just done a Land Rover Experience day I would like to get the ATPC activated as that is a very clever toy if you are offroad. More fiddling to be done!
Regards
Post #1047111 28th Sep 2024 4:15pm
cfong02
Park Assist - pending final verificationw
Hi Metisse, i have compared the CCF between a working and non-working park assist car.
I want to do some studies on your ECU too.
Mine is here: https://www.defender2.net/gallery/albums/u...2B2023.pdf
Please could you share yours?
Thank you
Post #1048155 9th Oct 2024 5:18pm
Metisse
Hi cfong02
I have uploaded my CCF to my gallery as a text file, feel free to play with it. I have managed to activate walk away locking on a 2022 car, ATPC, AT2 Auto and Configureable TR2, Park Assist (only tried parking in a bay not parallel parking). I have also set my speedo to read accurately and adjusted the ACC to match and turned off the persistent seat belt bong reminder.
I have entered all the changes for Tow Assist 2 but I have yet to try it. If this changes I'll let you know.
Have fun with comparing and let me know if there is anything else you need.
Regards
Post #1048169 9th Oct 2024 7:21pm
cfong02
Thank you Metisse, may I have your ECU export data?
Post #1048197 10th Oct 2024 2:32am
