Home > General & Technical (L663) > Gap Diagnostic Tool working Activations |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1396 |
I have tried to collate all the known working settings into this post, if anybody spots a mistake or has an addition to make just shout
Please don't reply to this post, lets keep this for the working list only, The main thread is here https://www.defender2.net/forum/topic85281.html ---------------------------------------- - Activate WIFI/WLAN Hotspot MultiCAN-814 IVIWiFiHotspot Standard: Not fitted Changed to: Internal WiFi Hotspot fitted ---------------------------------------- - Change Splash Screen to "Defender 007" EUCD-205 Racing Sub Brand Standard: Mainstream Vehicle Changed to: LTD 007 ---------------------------------------- - Dynamic Mode EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode" EUCD-245 Dynamic-I Standard: Dynamic-i Not Fitted Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen MultiCAN-562 DynamicProgMode Standard: Not available for selection Changed to: Available for selection without timeout Other possible value: Available for selection with timeout MultiCAN-605 ConfigDynamicMode Standard: Not Fitted Changed to: Fitted MultiCAN-777 Ter Dyn Select In FCPB Standard: Control interface not available in FCPB Changed to: Rotary used for selection within touch screen ---------------------------------------- -Remember Stop/start setting MultiCAN-566 MHLastUserMode = Enabled ---------------------------------------- For Walk away locking and Approach unlocking the general rule is that it is only available on MY2023 onward, if you don’t have a locking fuel cap you can enable both. You will also have to go into your centre screen setting and switch it on. Some people with earlier cars have got this to work but it is a bit of a lottery -WalkAwayLocking MultiCAN-505 Change it to Current: Enabled ---------------------------------------- -Approach unlocking MultiCAN-807 Approach Unlocking Disabled Change to Enabled ---------------------------------------- -Modify signature LEDs behavior MultiCAN-463 DRLBehWhilstDIsAct Current: Turn Off New: No Action MultiCAN-465 DRLBehWhHazardsAct Current: Turn Off New: No Action This setting is to keep them on while the turn signals or hazard lights are operating. ---------------------------------------- - The subwoofer was installed in the base model, but wasn't enabled. EUCD-121 Subwoofer Standard: Without Subwoofer Changed to: Subwoofer ---------------------------------------- -Enable All Microphones EUCD-126 Microphone = Four Microphones (Two Front & Two Rear) Standard: Microphone (Driver Only) ---------------------------------------- - Disable Seatbelt Reminder MultiCAN-717 Front Belt Minder Beltminder Fully OFF MultiCAN-737 Rear Belt Minder Rear Beltminder OFF ---------------------------------------- - MultiCAN-770 Remote Release Tailgate Enabled This will make the rear door pop open when you press the button on the key fob ---------------------------------------- -MultiCAN-723 Gloabal open/close MultiCAN 723 SMRF Global Close - changed to Enabled MulitCAN 719 CDL Global Close - changed to Enabled MultiCAN 719 CDL Global Open - changed to Enabled EUCD 184 Global Open/Close - changed to Global Open/Close Doors + Sunroof ---------------------------------------- - Configurable TR MultiCAN-736 Config TR Fitment - Not Configured > change to Off Road Configuration MultiCAN-755 Config TR Mode - Not available for selection > Change to Available for selection with timeout MultiCAN-797 Ter CT Select In FCPB > Change to Rotary used for selection within touch screen ---------------------------------------- - Disable drive away locking MultiCAN-740 Drive Away Door Lock to Disabled - To disable drive away locking ---------------------------------------- - Foglight with HighBeam EUCD-018 Foglight Function Foglight without restrictions MultiCAN-734 Front Fog Lights Oft High Beam. Set to Disable. ------------------------------------ - More accurate speed reading MultiCAN-838 from: Speedo market 0- 3.5% + 2kph To Speedo market 1- 2.0% + 0kph ------------------------------------ - Tow Assist2 MultiCAN-579 Tow Assist Set to Tow Assist 2 MultiCAN-635 Towing Set to Not Support if not already set to this setting. MultiCAN-696 ATCM TA2 Switch Set to Tow Assist 2 feature selection switch not fitted, again if not already set to this. MultiCAN-793 TA2 Input Control Set to HVAC rotary. MultiCAN-795 TA2 Select in FCPB Set to Rotary used for selection within touch screen. --------------------------------------- - After retrofitting 11.4" display MultiCAN-641 FrntUpperDispVariant Alpine 11.6 inch Single View Clarke4x4's thread on fitting larger screen https://www.defender2.net/forum/topic89297.html -------------------------------------- - After retrofitting ClearSight Interior Rear View Mirror MultiCAN-711 Interior Mirror Variant IRVM changed to SVRM Marco's thread on fitting Clearsight Mirror https://www.defender2.net/forum/topic88338.html -------------------------------------- - To turn off DRL / signature LEDs, aka "halos" in premium / matrix type headlamps: MultiCAN-468 FntDRLType Current: Incorporated DRL and Pos New: No DRL -------------------------------------- - To turn off Autohold Permanently MultiCAN-711 Auto Hold Current: HVH Enabled New: HVH Disabled -------------------------------------- - ACC Adaptive Cruise Control Requires IID Tool G4 to activate MultiCAN-580 PTCruiseFitment: ACC with Queue Assist fitted MultiCAN-712 ACC Lead Car Distance Display: Fitted MultiCAN-809 ACC Stop Gap Setting: Fitted -------------------------------------- All terrain progress control (ATPC) Requires IID Tool G4 to activate MultiCAN-476 ATPC Original: HDC Change to : HDC and LSPC -------------------------------------- Stop Driver assistance resets to High MultiCAN-889 GSR2 EU Market Ft Change it to Non GSR2 Country -------------------------------------- Configurable Terrain Response (TR2) Requires IID Tool G4 to activate MultiCAN-736 Config TR Fitment - Not Configured > change to Off Road Configuration MultiCAN-755 Config TR Mode - Not available for selection > change to Available for selection with timeout MultiCAN-797 Ter CT Select In FCPB Change to "Rotary used for selection within touch screen A couple of videos that should help new users How to enable the James Bond Screen How to email a copy of your CCF File to yourself Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 Last edited by Hairy Dan on 27th Jun 2024 9:31am. Edited 10 times in total |
6th Sep 2023 10:27pm |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 155 |
Thanks Ian for the work, very helpful.
Marco |
7th Sep 2023 7:26am |
Mark1107 Member Since: 19 Oct 2020 Location: Los Angeles Posts: 71 |
Ok, to camp or greenlaning,
We sleep in the back on camping trips. I disabled the vehicle waking up and the lights coming on or off with solely the tailgate/boot door opening and closing. Now for my regular contributions to the forums: Multican 703 “BCM interior light trunk” Fitted. Multican 703 BCMinterior light delay” Fitted. Immediately turns out all vehicle lights without a 30 second delay. So the 1st one stops ALL vehicle lights when trunk/boot door is opened or shut. The 2nd one immediately stops the lights when any of the 4 passenger doors are opened because our vehicles are set for a 30 second delay which drains the battery. 2022 Defender Trek Competition 110 collectors edition! 2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold) 2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair 2014 Range Rover L405 Autobiography Full Size Aintree Green 2014 Dodge Viper GTS Stryker Green |
6th May 2024 12:28am |
TSY Member Since: 27 Feb 2024 Location: Colorado Posts: 11 |
... a couple more that I didn't see above that I have adjusted. (MY24 110 P400)
____________________________ Wiper Drip Feature MultiCAN-726 Wiper Drip Wipe Feature Change to:Disabled ____________________________ Turn puddle lights off (if you're not a fan of the "graphics") EUCD-087 Puddle Light Stock setting: Outer Mirrors With Puddle Light (0x2) Change to: Without puddle light ____________________________ Disable the fake engine noises played through the stereo (or choose different versions) with these two settings: (I highly recommend disabling this on long roadtrips... it's more present than you think.) Next Generation Power Train Sound Quality (NGPTSQ) MultiCAN-584 NextGenPwrTrnSQ Select: Not Fitted MultiCAN-585 ActSndDesignPwrlvl Not Supported Select: Not Fitted * Both set to ' Not fitted ' for off |
9th Sep 2024 10:32pm |
Sticks999 Member Since: 10 Sep 2024 Location: Durham Posts: 3 |
Hi has anyone managed to get park assist to work. I have entered all of the below and everthing is present but the Start button is greyed out.
Park assist settings Activate Park Assist EUCD-059 Parking Assistance Standard: Without Parking Assistance Change to: PDC (Front, Rear) - Parking (Parallel, Exit) EUCD-099 Park Assist Camera Standard: Without Park Assist Camera Change to: With Park Assist Camera EUCD-140 Pdcautoactivationmenu Standard: Not supported Change to: With PDC Auto Activation menu MultiCAN-469 PDCAutoActivation Standard: Not Supported Change to: Default OFF configurable MultiCAN-500 PDCBtnFCIM Standard: Not supported Change to: Fitted MultiCAN-602 PDC Standard: PDC not fitted Change to: 10 Channel fitted ( Park Assist) MultiCAN-786 Park Assist Standard: Not Fitted Change to: Full Auto VarD (Fully automated park assist with automated steering breaking acceleration and gears) • Needed 2 resets to PIVI for the app to appear in PIVI and a full car shut-down to clear the "Emergency Brake Assist Unavailable" error. |
10th Sep 2024 11:50am |
