Home > Puma (Tdci) > Suspension Rattle or something else?
S7eve
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
My 90 has a nasty mettalic rattle from rear.
It only happens when going over several small bumps one after each other, never over big bumps or when car is loaded or has rear passengers.
Bouncing on rear , or on side steps when stationary does not case rattle
Vehicle has had Alive road springs and Fox forks fitted.
Everything appears properly bolted.
Any ideas what it could be Guys?
Post #1044210 29th Aug 2024 8:58am
landy andy
Bottom damper mounts
Fuel tank heat shield
Fuel filter cover
And a recent one that I had was diff cover slightly bent, so just rung, when the bump was correct, but only applies if you have diff protection, which I doubt you do with lowering springs.
Post #1044211 29th Aug 2024 9:24am
Does it do it if you lightly apply the brakes? It is very common for the rear pads to rattle in the callipers.
Post #1044214 29th Aug 2024 9:40am
Ianh
If it is the rear pads then this topic may help. https://www.defender2.net/forum/topic78504.html
Post #1044216 29th Aug 2024 10:09am
Check the A frame bushes and ball joint for movement whilst giving it a pull around. TheThunder Rolls🇬🇧🇺🇸
Post #1044228 29th Aug 2024 12:18pm
markb110
You haven’t left a spanner loose in the back somewhere…..?
Post #1044242 29th Aug 2024 2:18pm
Zed
All the above plus check the exhaust isn’t bouncing off the chassis. It’s a slightly deeper sounding metallic clang. WARNING.
Post #1044267 29th Aug 2024 5:41pm
S7eve
Thanks for suggestions Guys,
I have now checked all -
Damper Mounts, bushes and ball joints,Tank Fuel shield, Exhaust, loose spanner etc and thought the Fuel Filter cover could be the culprit. However it still makes the noise with it removed.
Also removed rear wheel carrier and checked door hinges. Have removed r/h rear seat although sound does not seem to be coming from interior.
It is not brake related.
It sounds to be coming more from drivers side rear.
Any other suggestions apart from turning up radio
Post #1045309 9th Sep 2024 2:41pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Couple of other options to try:
Mudflap bracket
Anti roll bar ball joints
Post #1045312 9th Sep 2024 3:09pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
Presumably you’ve checked to see if the prop shaft uj’s aren’t loose? When they’re worn out and dry out they can rattle.
Post #1045362 9th Sep 2024 9:04pm
Puma_MOG
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Any chance it's coming from within the cabin? I only ask due to my rear forward facing seats can make such a noise if not fully locked in place when the seats are in the upright position.
Good luck with the search.
Post #1045481 10th Sep 2024 8:01pm
