Home > Puma (Tdci) > Suspension Rattle or something else? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5753 |
Bottom damper mounts
Fuel tank heat shield Fuel filter cover And a recent one that I had was diff cover slightly bent, so just rung, when the bump was correct, but only applies if you have diff protection, which I doubt you do with lowering springs. |
29th Aug 2024 9:24am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17492 |
Does it do it if you lightly apply the brakes? It is very common for the rear pads to rattle in the callipers.
29th Aug 2024 9:40am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2079 |
If it is the rear pads then this topic may help. https://www.defender2.net/forum/topic78504.html
29th Aug 2024 10:09am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20512 |
Check the A frame bushes and ball joint for movement whilst giving it a pull around. No Guts, No Glory.
29th Aug 2024 12:18pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2649 |
You haven’t left a spanner loose in the back somewhere…..?
29th Aug 2024 2:18pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3334 |
All the above plus check the exhaust isn’t bouncing off the chassis. It’s a slightly deeper sounding metallic clang. WARNING.
This post may contain sarcasm. |
29th Aug 2024 5:41pm |
S7eve Member Since: 19 Feb 2024 Location: Derbyshire Posts: 4 |
Thanks for suggestions Guys,
I have now checked all - Damper Mounts, bushes and ball joints,Tank Fuel shield, Exhaust, loose spanner etc and thought the Fuel Filter cover could be the culprit. However it still makes the noise with it removed. Also removed rear wheel carrier and checked door hinges. Have removed r/h rear seat although sound does not seem to be coming from interior. It is not brake related. It sounds to be coming more from drivers side rear. Any other suggestions apart from turning up radio |
9th Sep 2024 2:41pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 670 |
Couple of other options to try:
Mudflap bracket Anti roll bar ball joints |
9th Sep 2024 3:09pm |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 488 |
Presumably you’ve checked to see if the prop shaft uj’s aren’t loose? When they’re worn out and dry out they can rattle.
9th Sep 2024 9:04pm |
Puma_MOG Member Since: 08 Sep 2017 Location: Cheshire Posts: 184 |
Any chance it's coming from within the cabin? I only ask due to my rear forward facing seats can make such a noise if not fully locked in place when the seats are in the upright position.
Good luck with the search. |
10th Sep 2024 8:01pm |
