![]() | Home > Puma (Tdci) > Defender knocking noise and smoke |
Sam smith Member Since: 12 Aug 2021 Location: Suffolk Posts: 68 ![]() ![]() ![]() |
Any help would be really appreciated.
Just finished rebuilding my defender 2.4 tdci went for a drive up the road to check all ok. It was driving nicely for 10 mins then all of a sudden it starts doing this as in the video. I don’t want to run it for long and towed it home. I’ve added nanocom faults Any suggestions? Many thanks |
I can’t seem to upload the video of the noise.
No when I say rebuild I mean put the defender together rather than rebuild the engine. |
I have put the video on the defender puma owners group on Facebook
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 931 ![]() ![]() ![]() |
Did you remove/refit injectors? 2008 2.4 110 Utility Station Wagon XS.
Hi
No I haven’t touched any of the engine components just fitted. What is strange is that it has been running fine and drove fine for a few km then suddenly stopped? |
Evil Elsie Member Since: 25 Feb 2023 Location: Cumbria Posts: 206 ![]() ![]() ![]() |
I've not heard the noise but...
Are the Propshaft (I'm obsessed with these things at the moment) bolts tight..?? 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5868 ![]() ![]() |
Any oddness to a Tdci engine I recommend swapping out the VCV, as they are delicate, not expensive and easily swapped. Mine when failed created an engine knock.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20749 ![]() ![]() |
Does sound VCV like, other DTC’s might be flagged just because of the motor shut down because of it as a kind of side effect. WeWillWin🇬🇧🇺🇸
