Home > Technical > Leaking power steering from small hole on the back |
SebastianK Member Since: 07 Aug 2020 Location: Copenhagen Posts: 11 |
I can see light from the other side in the hole, so is this a drain hole from the inside/other side (towards the engine)?
Click image to enlarge The side towards the engine seems dry at side/top/bottom of pump seal? π΅βπ« Click image to enlarge Click image to enlarge |
7th Aug 2024 3:25pm |
Not that there was that many suggestions π
But if anyone in the future runs in to a similar problem, I ended up just changing the pump with a new one and that fixed the problem π
8th Sep 2024 7:40am |
