Home > Maintenance & Modifications > Windscreen Washer Upgrade
kljw
Scotland 2009 Defender 90 Puma 2.4 SVX Soft Top Auto Santorini Black
Hi
does any know, if there is an upgrade kit for the washer system on the defender (puma) that will attach to the wiper blades themselves, and spray water directly onto the window? or, have any suggestions on how to go about it? Cheers
keith
puer claudius
Post #10410 1st May 2009 11:53am
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
On a similar subject does anybody know how to get to the wiper mechanisim as one of my wipers is making a right clicking sound?
Post #10412 1st May 2009 12:03pm
110SEB
This topic has done the rounds, but this article is very useful
http://www.reedx.net/landrover/mods/wipers/index.htm
Thumbs Up
Post #10413 1st May 2009 12:07pm
Glynparry25
Thumbs Up
That is exactly the same as we did with the snatch land rovers- very simple and all you need to d is get down the scrappy to get the attachments for the wipers.
Glyn
Post #10421 1st May 2009 3:49pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Take it back to the dealer Thumbs Up Its still under warranty Thumbs Up
Post #10428 1st May 2009 8:28pm
Sonic3d
I`ve been at Allisport`s all day and we were talking about the exact same problem, Andy fitted today some Disco2 headlight washer jets to the bonnet of his Wildcat complete with the washer pump, it works really well.
I was thinking about mounting some jets on my bonnet.
Post #10429 1st May 2009 8:33pm
discocuzzy
Not more bolt ons! Whistle You cannot teach stupid people to do clever things
Post #10431 1st May 2009 10:07pm
Sonic3d
Oh yes Thumbs Up
Post #10432 1st May 2009 10:32pm
MK
My washer blades are a piece of s?=)t with 15000km. Yours also?
I was thinking also on some sort of washer upgrade. But, probably the bonet is a bit far from the windscreen. Puma 110" SW
Post #10443 2nd May 2009 2:56pm
mse
VWP do the unit to attach to the arms - Mike
Post #10449 2nd May 2009 8:50pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Technical bulletin:
Summary:
Windshield wipers juddering or making a knocking noise when operated. Note that
windshield wiping quality is not affected by this issue.
Before proceding, note that the following conditions are not associated with the two
symptoms described above and therefore not covered by this bulletin:
NOTE: Where there is evidence that parts which do not suffer from these conditions have
been replaced against this bulletin, the warranty claim may be rejected.
Fuel damaged parts.
Parts damaged in car washes.
Bent levers or primary yokes (wiper blade structure).
Bent arm-pieces to modify the attack angle.
Damage of the wiping edge of the blade - torn or sections missing.
Damage to the wiper blade rubber due to contamination with solvents or silicon-based
products.
Contamination on the wiper blade which would prevent the blade from performing as
expected; the function of the wiper blades is to clear the screen of water. Examples are:
Fuel, wax, dirt, bird excrement, dead insects, plant material.
Technical Bulletin LTB00068 should also be referenced to ensure the root cause of any
judder/noise is not due to a permanent set condition of the wiper blade.
Cause: Condition of the wiper arm mounting or spindle
Action: Should a customer complain of the above symptoms, the cause should be
diagnosed, and if relevant cause is found, after carefully reviewing the notes
above regarding other conditions/actions, the windshield wiper arm should be
replaced. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #10466 3rd May 2009 8:23pm
