Home > Puma (Tdci) > Picture Request - factory fitted carpets/floor mats
Puma_MOG
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Good day All,
A bit of an odd one...
I am hoping someone would be so kind in taking a few pics of their front footwell with the factory fitted floor mat removed. As I understand it there are plugs in the floor to allow a fir tree of some type to secure said carpet.
Many thanks!
P
Post #1044151 28th Aug 2024 5:35pm
There are two holes in the floor in each foot well. In each hole is a plastic thing called a snapsac, and the fir tree pegs lass through the carpet into the snapsac. It's a crude and clumsy arrangement but it works.
I'll try to dig out the part numbers tomorrow but it's all been covered well on here before.
Post #1044154 28th Aug 2024 5:58pm
Puma_MOG
Thank you for that.
I found the parts and assumed so but wasn't sure how the snapsac was fitted. I can only assume a hole is drilled out and the snapsac fitted.
My 90 didn't come with carpets but have since fitted factory carpets in all areas bar the footwell and the rear load area which I am now thinking I might, hence the ask.
Thank you again blackwolf. A pic would be greatly appreciated.
Post #1044159 28th Aug 2024 6:24pm
Alpine
Netherlands 2009 Defender 130 Puma 2.4 HCPU Stornoway Grey
I was looking for the same yesterday. Partnumber is AJU1136L, name is 'stud anchor'
Post #1044164 28th Aug 2024 6:59pm
Puma_MOG
Thank you for that.
I've got those as well, it's how it's set into the cabin that I am curious about.
Post #1044206 29th Aug 2024 8:19am
jcw
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Just pushed through a drilled hole in the floor plate.
Post #1044208 29th Aug 2024 8:41am
TexasRover
You mean the drain hole
Post #1044217 29th Aug 2024 10:18am
