Home > Puma (Tdci) > Picture Request - factory fitted carpets/floor mats |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17386 |
There are two holes in the floor in each foot well. In each hole is a plastic thing called a snapsac, and the fir tree pegs lass through the carpet into the snapsac. It's a crude and clumsy arrangement but it works.
I'll try to dig out the part numbers tomorrow but it's all been covered well on here before. |
28th Aug 2024 5:58pm |
Puma_MOG Member Since: 08 Sep 2017 Location: Cheshire Posts: 184 |
Thank you for that.
I found the parts and assumed so but wasn't sure how the snapsac was fitted. I can only assume a hole is drilled out and the snapsac fitted. My 90 didn't come with carpets but have since fitted factory carpets in all areas bar the footwell and the rear load area which I am now thinking I might, hence the ask. Thank you again blackwolf. A pic would be greatly appreciated. |
28th Aug 2024 6:24pm |
Alpine Member Since: 23 Feb 2024 Location: brabant Posts: 8 |
I was looking for the same yesterday. Partnumber is AJU1136L, name is 'stud anchor'
28th Aug 2024 6:59pm |
Thank you for that.
I've got those as well, it's how it's set into the cabin that I am curious about. |
29th Aug 2024 8:19am |
jcw Member Since: 11 Sep 2016 Location: Gloucestershire Posts: 168 |
Just pushed through a drilled hole in the floor plate.
29th Aug 2024 8:41am |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1052 |
You mean the drain hole
29th Aug 2024 10:18am |
