Home > General & Technical (L663) > Rust
Defender2020
Sweden
Rust
I have just purchased a new to me, low mileage Defender 110 240. As you can se from the pictures below, there are already spots of rust both in the undercarriage, which is mostly bolts / washers rusting but also other parts. Do you have any tips on how to treat these so it looks better and how to maintain to ensure there won’t be as much rust in the future?
As you can see, one of the four screws in the trunk has also rusted, weird because it is only this one. I tried to screw it out but it didn’t move. Seems like you can’t screw them out. Anyone know how to get it replaced with a new one, and have the correct part number?
Post #1044120 28th Aug 2024 3:17pm
TexasRover
Yeah pretty normal I would think of any modern car in the north. They design each part to be sufficient and this is what you get - does the job. If you look at u-tube channels like South Main Auto you will find that modern cars last about 8-10 years in the US rust belt.
Best way to address is to use a fluid-film type product and regularly apply.
Post #1044127 28th Aug 2024 3:45pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
We have the same issues with corrosion in Scotland, I'm about to treat my old 110 with Lanoguard to try and provide some protection
https://www.lanoguard.co.uk 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #1044137 28th Aug 2024 4:42pm
DrRob
I’m using XCP. Done the sub frames on day 2 post collection
 MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie"
Many Range Rovers and Land Rovers over the years 😂
1949 80" - still in family since 1975
Post #1044138 28th Aug 2024 4:52pm
LR Nuts
this vehicle has been used somewhere near the sea and in a country that salts roads in the winter
Post #1044140 28th Aug 2024 5:00pm
lightning
Here's mine after two years.
Sprayed everything with XCP rust protection when it was new. Re applied after 12 months. The whole underside is totally free of surface rust.
Post #1044141 28th Aug 2024 5:02pm
Defender2020
Sweden
Many thanks for all replies. I have found a site that sells XCP and ships to Sweden. Should I first try to scrape away rust before applying? Maybe clean it first and let It dry also I assume? I Would like to replace the bolts but might not be worth it.
Post #1044162 28th Aug 2024 7:37pm
lightning
Any wax based clear rust proofing product will do.
As it's only surface rust l wouldn't be too worried about cleaning it off, before spraying the clear wax coat.
But you could remove any loose rust.
Post #1044187 28th Aug 2024 10:25pm
H1Tad
United States
Over here in the Northeast we brine our roads in the winter. My cars all get coated in a product called NH Oil which is a sticky oil that coats thr entire underbody of the vehicle and blocks and displaces water.
It does make the whole underside a terrible mess to work on. But it works extremely well. Picture for reference of what it looks like once treated
As for the rust on the bolts in the original post... it's surface rust. You could actually probably use a brass brush to knock it off.. or use a rust converter. Then you can treat it with a protection product like the ones mentioned in the thread. Another option is to clean them and hit it with Steel-it paint which is a paint that contains stainless steel and is very corrosion resistant. Pretty pricey though. 2022 Defender 110 SE P400 Tasman Blue Expedition and Cold weather package
2003 Hummer H1 P400 Firehouse Red
2008 Toyota FJ Cruiser
Post #1044188 28th Aug 2024 10:47pm
LR90XS2011
take a look at the corrosion prevention guide and then contact Zegato on here
https://www.defender2.net/forum/topic10467.html?highlight=rust DEFENDER 90 TDCI XS,
Post #1044189 29th Aug 2024 6:19am
