Home > Puma (Tdci) > Engine Rattle/Ticking - TDCI 2.4 2009 DEFENDER 110
miles_thedefender
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Hi All,
I greatly appreciate any help you can provide, so thank you in advance.
My 2009 Defender 110 2.4 TDCI has been running well for the past few months. However, after returning from Devon last week, I noticed a loud ticking noise coming from the top of the engine, although it was still driving fine.
I posted a video in the Puma FB forum, which you can hopefully view here:
https://www.facebook.com/groups/1065881687...7022542034
The general consensus, and after consulting with a local mechanic, pointed to the injectors or washers ect being the issue. The mechanic confirmed that Cylinder 2 was not reading right and suggested replacing all four injectors since they were likely on their way out. I ordered new injectors, and the mechanic installed them this morning.
Unfortunately, the noise persists.
His computer showed the numbers on the cylinder in positive and the 3 others were showing negative readings.
The mechanic is uncertain about the next steps and has suggested replacing the Rocker Arm and Valve Housing, suspecting the rockers might be causing the ticking noise.
Does anyone have further suggestions? Are there any TDCI specialists around SW England who might be able to help? Given how common this engine is, I'm hoping someone out there knows what the issue could be.
Post #1044008 27th Aug 2024 1:14pm
Are you sure it isn’t the turbo heat shield? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1044013 27th Aug 2024 3:18pm
miles_thedefender
No, its nothing to do with the heat sheild, I thought the noise was coming from there originally but its defo in the engine/injector area.
Post #1044014 27th Aug 2024 3:19pm
jst
Auto solutions poc Paul, Axminster. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1044056 27th Aug 2024 8:30pm
Bulletbrindle
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Your mechanic sounds more like a part changer to me, blindly guessing at would could be the issue and costing you loads of money at the same time
Post #1044095 28th Aug 2024 10:12am
That is common, Rolling Eyes for example offering Turbo replacement when only the EA needs replacing.
Fuel pump replacement when only the VCV needs replacing, and things like that. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1044110 28th Aug 2024 12:09pm
spudfan
Ireland
Had a rattle in the engine bay of a 2.4 Puma. Turned out to be the metal heatshield cover on the turbo needed tightened. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1044335 30th Aug 2024 7:37pm
Zed
Mark at Broad Lane in Westbury. WARNING.
Post #1044693 3rd Sep 2024 5:31pm
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
I had this it was VCV valve on the back of the pump sticking. Not uncommon but you need small hands to change it.
Can sound like a bag of spanners when the VCV plays up. 2008 Defender 110 XS CSW
Volvo S60 T8
Triumph 1200 Rally Explorer
G0UBX
Post #1044758 4th Sep 2024 9:16am
lightning
Looks like the O/P disappeared. l hope he got his Defender sorted, it would be useful to know what the fault turned out to be.
Post #1046505 22nd Sep 2024 5:52pm
