![]() | Home > My Defender > Parents 200 TDI |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2710 ![]() ![]() |
Looks rushed, with the cheapest parts possible used. Can I ask the obvious question of why would you accept it back in that condition?
revd Member Since: 20 Apr 2024 Location: England Posts: 199 ![]() ![]() |
over-length bolts are a joke- are they even the correct grade of steel?
(aero spec is one and half threads clear of the nut) missing cross-member is criminal looks like a case for trading standards |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3486 ![]() ![]() ![]() |
The extra threads for the shock brackets are only a problem when you need to undo them after corrosion starts setting in. The immediate problem is that they used undersized washers, and given how much thread is exposed, probably they are full thread bolts, which are inherently weaker. The smaller washers could allow the nut to be pulled through the chassis, although I don’t know what size crush tubes Richards use.
The exhaust is a joke. Could be a Discovery 1 exhaust (still a 200tdi)? Which would be their mistake at ordering? The way the seat box is bolted to the tub…. 🤦🏼♂️ Was the seat box side replaced? I replaced mine with an aftermarket one, and it was all wrong, with missing pressing to allow where metal is doubled. Easy to correct on a small press, but takes extra time. More of a problem is what you don’t see, and not what you see! 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 854 ![]() ![]() ![]() |
My thoughts
I would list all the bad workmanship and delays and send it to the owners of the garage and ask for a partial refund. If you get no joy then I would start a small claims court case against them. Sometimes just having County Court papers served on them will give them the kick up the backside they need to provide a refund. Also report to your local Trading Standards. For £27k you could have bought one of the last Defenders built with low mileage... https://www.gov.uk/make-court-claim-for-money Jim |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5242 ![]() ![]() |
only thing it was accepted back at the time, was that they were going away to scotland, with the caravan, on the friday that week. The parents only had the Thursday to pack, and test everything, they would have been a way the early hours of Friday morning. Also My dad is far too quiet for his own good, and my mam wasn't around with her been at work. To keep a check on progress etc. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
God knows what bolts have been used, i am suspecting they just went to the local ability supplies and bought bags of nuts and bolts. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
We are suspecting that the seat box is someone else's, its not the one me and my dad rebuilt. We used YRM metals. I did look at the disco units as well as the 110s and they just match that at all. I am starting to suspect its a one that they have knocked up. Back box or silencer is practically under the driver seat. Laugh was when it was leaking fuel, i said lets check the fuel lines, Sure enough, those were just hand tight, which would have worked lose. So god knows what else is done. Washer side of things, when we put the driver side sill back together. I swopped the small washers they used. for the proper size ones. The floors are all bolted down too, so which again point to the cheap hardware. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
Jim, things that they pointed out, were not even sorted till months later. Wiring been one of them, which to me, would should have been a replacement car loom if needed be, they drafted in some fella who faffs on with these. To finish this off, and do some wiring to it. Basically all the stuff that we could wire in our selves, heated window screen been one of them. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
A little update on our Terr, My dad has started to get his arse back into action, and refit some of the parts,
![]() Click image to enlarge ![]() Click image to enlarge Those need rewiring in, as they just removed and chucked the loom, me and my dad bought. ![]() Also my dad has put in the chassis support back in place, that they left off. ![]() ![]() Click image to enlarge ![]() Click image to enlarge Another big milestone for them, They winged on at me for not getting them anything for their birthdays, But with BeaTie giving me a 1900 bill, i had to hang fire. Until I got my funds back up again. I was keeping my eye on the optimill remover able boss package that was for sale on here. The seller did have some interest, but no takers, so i thought yep i will have that. ![]() I asked the seller to address it to my parents, and a giggle that was. My mam messaging me, have you sent us a parcel?? When they opened it up and saw it. My mam was over the moon. my dad was keen to put it on the car. but waited until they got the orange lock for it. ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10894 ![]() ![]() |
All good with the progress Procta
this has spent more time off the road, since its come back, and my dad is not really keen on taking this back to have things checked over. i don't blame him, the alarm their charged for isnt exactly installed properly. To me id just cut my losses and go back to who did the original alarm. ( the ones who rebuilt this, decided to cut the thing. ) Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
After some digging, we did manage to find a photo off the prats who stripped this down, and it did have a brake valve thing, you can just say make it out. So i ordered off a replacement.
So we fitted it ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Oh yeah we also corrected their shoddy pipe work on the driver side too, I thought i took a photo, but looks like i didn't. They had bent the pipe to the point it was nearly 90 degrees, to fit it on the flexi hose. It was wedged between the chassis and the inner wing. So god knows what he was thinking there! So that was took off and redone properly ![]() Click image to enlarge The bonnet cable also had to be sorted out, due to that been right out. Also a return spring is missing ![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
what ever these fools have done to the brakes, they need their fingers broken
![]() ![]() ![]() so this is more wages my dads had to fork out and we have to correct, its been off the road more times this year, since these fools have rebuilt it. " needs a 500 mile around test, then returned for a nut and bolt check" Its not even done 30 miles and its had god dam problems. I think a few fingers need to be broken here ![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2199 ![]() ![]() ![]() |
And how have you not called them out??
