![]() | Home > My Defender > 110 Puma to M57 and 8 speed auto |
biasbilt Member Since: 05 May 2024 Location: Devon Posts: 3 ![]() ![]() |
I wouldn't try to use the PCS controller, would go straight to Turbo Lamik
mata Member Since: 24 Jan 2014 Location: Manchester Posts: 153 ![]() ![]() ![]() |
Oh, I thought you meant in your previous post that you were using a PCS ECU.
Same advice stands though, would suggest you check with Lamik about integration with your ECU. |
Jason-SEK Member Since: 30 Jun 2024 Location: Germany Posts: 14 ![]() ![]() ![]() |
Hi Mata, which 8HP70 to LT230 adaptor kit you are using? And would you recommend it or go down a different path? Thanks a bunch!
I’m using the syncro gearboxes kit. It’s shorter than the wiseman one I believe the Wiseman kit is a bit longer but mounts up to the LT 230 in more places.. The downside of the synchro kit is that you can’t remove the electrical connector from the gearbox without dropping off the transfer box, although this in reality isn’t actually in issue. In terms of build quality comparison et cetera I’ve no idea because I’ve never actually seen a Wiseman adapter up close and personal..
Thank you, Mata, for this valuable info!!!
Barrytilt Member Since: 27 Oct 2021 Location: Cape Town Posts: 2 ![]() ![]() ![]() |
Thanks a few years on and I’m starting with the m57 and 8 speed auto I think most connectors are off the shelf now, but here in South Africa not so easy, thanks for the info.
