Home > My Defender > 110 Puma to M57 and 8 speed auto
Page 9 of 9 <123456789
mata
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
How straightforward it is getting the turbo Lamik to work will depend a lot on integration with your ECU. I’m aware a lot of people who have worked with Łukasz Lamik and he has helped with software and setup for various aftermarket ECUs, but I’m personally not aware of a PCS being used before.
I’d suggest you drop them a message and see what they say first.
Post #1034537 12th May 2024 1:24pm
biasbilt
I wouldn't try to use the PCS controller, would go straight to Turbo Lamik
Post #1034593 13th May 2024 7:02am
mata
Oh, I thought you meant in your previous post that you were using a PCS ECU.
Same advice stands though, would suggest you check with Lamik about integration with your ECU.
Post #1034599 13th May 2024 7:24am
Jason-SEK
 2008 Defender 110 Puma 2.4 SW Santorini Black
8HP70 to LT230
Hi Mata, which 8HP70 to LT230 adaptor kit you are using? And would you recommend it or go down a different path? Thanks a bunch!
Post #1043677 23rd Aug 2024 4:44pm
mata
I’m using the syncro gearboxes kit. It’s shorter than the wiseman one I believe the Wiseman kit is a bit longer but mounts up to the LT 230 in more places.. The downside of the synchro kit is that you can’t remove the electrical connector from the gearbox without dropping off the transfer box, although this in reality isn’t actually in issue. In terms of build quality comparison et cetera I’ve no idea because I’ve never actually seen a Wiseman adapter up close and personal..
Post #1043681 23rd Aug 2024 5:30pm
Jason-SEK
Thank you, Mata, for this valuable info!!!
Post #1043683 23rd Aug 2024 6:11pm
