Home > Td5 > engine management light / missfire
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
Hi have been driving on s plain all day throgh some deep water. Now have really bad misfire and when try to rev engine yellow engine management light. Engine will tick over quite happily.No water in air box, disconnected maf makes no diff. Not oil in ecu. Does anybody hav3 any ideas. Thanks in advance.
Post #104363 3rd Dec 2011 8:45pm
bob neville
Long shot - water got into the fuel system somehow or water ingress into the air filter ?
Bob
Post #104365 3rd Dec 2011 8:50pm
BigMike
Is it smoking at all? if so what colour?
Post #104366 3rd Dec 2011 8:57pm
amondeggs
Hi mike, not my day. No no smoke. Started as intermittent misfire that got worse. Then yellow eng managent light and no rev at all. Stuck at hotel scratching head?
Post #104368 3rd Dec 2011 9:01pm
BigMike
check the dipstick - is the oil a bit milky? if it is don't start it again.
just wondering about the crankcase breather but that exits into the air pipe anyway.. If it's starting ok and ticks over and the engine doesnt sound like a bag of old spanner then its not been hydrolocked
If there is no water in the airbox at all and the filter is dry with no signs of having been wet (ie wavy) then I guess it must be electrical/electronic. Do you know someone close by with a diagnostic? that will tell you pretty quickly, but clearly its water related.
Post #104379 3rd Dec 2011 9:27pm
amondeggs
Mike it ticks over as normal. Air box bone dry. Long way from home as you know. When. tixking over and push avcelerator pedal then you get yellow engine light. Oil is normal.
Post #104381 3rd Dec 2011 9:33pm
markb110
Hi Amond
Good to meet you today
Sorry to hear of your problem
Found a couple threads with a similar issue:
'Vacuum hose between modulator and turbo outlet hose had a crack in it'
and this
TD5, 80k miles, with a fsh started 'misfiring' under load and above about 2,500 RPM. Of course being a diesel misfire is not the correct term - but it ran rough and would not pull, seemed short on power. The problem was only apparent under load, when accelerating hard, or uphill and only when revs got beyond 2,500 or so, although this varied a little between 2,500 and about 2,900.
The injector harness has been changed for a new one with improved sealing.
No problems starting, idling or driving gently about town or up to about 65mph so long as acceleration is gentle.
A dealer check showed no fault codes, although the air flow was a little low so they swapped out a MAF meter, no improvement, so they put the old one back in free ( amazing)
After lots of searching on the internet I cam up with a long list and started at with the simplest and cheapest items.
Step 1) Checked red plug on ECU, still some oil despite injector harness change, must be residual oil in engine harness, cleaned it out, no improvement
Step 2) Checked other end of harness where new injector harness plugs into engine harness, no oil
step 3) Removed turbo heat shield and disconnected wastegate actuator rod, found wastegate to be very stiff. It freed up easily with some oil, replaced everything and problem solved - its great to have full power back.
It seems as if the wastegate was not opening under heavy load, so boost pressure was getting too high and so the ECU was shutting down fuelling to protect the engine, hence the rough running and poor performance.
Hope that you get it fixed soon
Mark
Post #104382 3rd Dec 2011 9:35pm
amondeggs
Thanks mark will have look at hoses etc in light in morn. Don't fancy low loader home!
Post #104387 3rd Dec 2011 9:41pm
T1G UP
thottle pedal get wet?
Post #104388 3rd Dec 2011 9:43pm
amondeggs
Yes I suppose it did a bit. Had some water come into footwells mostly under mats tho.
Post #104390 3rd Dec 2011 9:47pm
wslr
If you've got the MIL illuminated ot could be the crank sensor having a fit - it can get dirty inside the bell housing and water ingress makes it difficult to keep the sensor clean enough to run at higher revs.
Its easy with a Defender to pull the sensor and quickly check to see if it is dirty.
Is the clutch on its way out at all?
Post #104396 3rd Dec 2011 9:56pm
amondeggs
Is the crank cas3 sensor easy to find / access?
Post #104400 3rd Dec 2011 10:01pm
wslr
It's the crank shaft sensor you are after. If you open the bonnet and stand on the driver side to look at the bell housing at the back of the engine, if you look closely there is a bolt holding a black sensor and multiplug to the bellhousing.
Without a clear signal from this sensor you'll get a misfire as the engine loses the signal to time the engine.
Post #104408 3rd Dec 2011 10:10pm
amondeggs
Thanks to all that have replied. Phone now flat, I'm nackered so please of you have any more ideas please post and I will read th in am..
Post #104409 3rd Dec 2011 10:11pm
wslr
Best I can find to help you.
Post #104412 3rd Dec 2011 10:31pm
