Home > P400e Area (L663) > Replacing PHEV main batteries - any idea on cost?
Ritson
France
Just wondering if anyone knows the approximate cost of replacing the main batteries when the time comes. Mine's coming up to 3 years old now and the max range has dropped by about 10%. I seem to remember reading somewhere that LR guarantees a 70% battery capacity up to 7 years.
I'm hoping by then alternates to OEM batteries may be available which offer greater capacity therefore greater range?
Cheers in advance Current: MY22 P400e SE
Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue
Post #1043318 20th Aug 2024 3:53pm
Crazymind
My EV battery, 90kwh would be 40k to replace today. Takes into account 8k to pay the garage to swap the battery.
Reasonably to replace your battery today you are looking at 8/10k at least in Uk.
Battery at 70% means it’s done. In 7 Years I would expect to get new gen batteries with different chemicals, more density and capacity and same volume.
Post #1043371 20th Aug 2024 8:48pm
markb110
Throw in vehicle depreciation then in reality you are looking at scrap value in the long run.
Even in the e-bike world no third party supplier is making replacement batteries for older models, and they have been around longer.
Modern vehicles are just not meant to be kept. Unfortunately you just have to know when to cut your losses, it also means this is how they will get you into a fully electric car even if you don’t want one.
Post #1043404 21st Aug 2024 7:16am
Ritson
France
Thought as much. I'm intending keeping mine for some years yet, so I think spending another 10k in 4 years time will be worth it. Current: MY22 P400e SE
Post #1043421 21st Aug 2024 8:43am
Moo
Ukraine
I'm going to be on dinosaur juice for many years yet... Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1043424 21st Aug 2024 8:47am
Gareth
Maybe PHEV batteries will need replacement sooner than BEV vehicles? They work harder. Our EV (Vw) is coming up to 4 years old, and the battery health is still at 100%. The range is the same today as it was when new.
We usually only charge to 80% which covers our needs, only charging to 100% when necessary. Do PHEV owners always go to 100% charge? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #1043518 22nd Aug 2024 6:22am
ardevd
Norway
A battery health of 100% after 4 years would defy physics. I strongly suspect that number is incorrect.
Yes, PHEV batteries go through a much higher number of cycles but they also have a significantly larger buffer, meaning they don’t necessarily reach harmful states of SoC. Hence longevity should be pretty comparable to BEVs.
Post #1044620 3rd Sep 2024 12:12am
Crazymind wrote:
... In 7 Years I would expect to get new gen batteries with different chemicals, more density and capacity and same volume.
With current trends I would expect the vehicle to be obsolete in seven years, so although I have no doubt that much better batteries will be available I wouldn't necessarily expect that they would fit a seven-year-old vehicle.
Post #1044634 3rd Sep 2024 7:43am
TexasRover
The technology to the rescue phenomena must have a lot of confirmation bias.
Sure there are examples were technology has solved big challenges: LED lights, consumer electronics, anything with electronics, but there are an equal or more examples where it has lead to nothing: Living in space, flying cars, unlimited energy, various social issues.
I think batteries might have reached this point where we might see incremental changes only. Surely a battery with immense power density, enormous charge and discharge currents and infinite life would have been invented by now.
I also don't see any development towards sustainability in general with shortening of equipment life cycles, no repairs possibilities, software dependence an other planned obsolescence.
Its all a con. In any case society's demised is more likely to come from social media than the environment I think
Post #1044643 3rd Sep 2024 10:40am
ardevd
Norway
I disagree!
Firstly, a common misconception is that faulty battery packs mean the entire battery pack needs to be replaced. A BEV battery consists of a large number of individual cells that can be swapped out if any one of them get faulty.
Secondly, second hand BEV batteries are being used for renewable energy storage to great effect!
Thirdly, there’s ALOT of R&D into battery technology, and if you look at EV range increases over the last few years we’ve almost doubled efficiency of EV batteries in a relatively short amount of time.
Lastly, EV batteries are generally extremely durable when treated well.
Post #1044987 6th Sep 2024 7:59am
Brulz
Italy
Engine light switch on today...
BECM DTC P0A7F-00 confirm the Hybrid Battery Pack "A" Deterioration...
My dealer hope the warranty will cover the replacement...
the cost of the battery pack (in Italy) is about 13.000 euro + VAT and installation.....
Post #1054495 12th Dec 2024 2:36pm
Ritson
France
Interesting and disconcerting! My P400E is booked in to the dealers on Monday as I too have an engine warning light, or did as it has now subsequently gone off after 4 days. I will keep the appointment and see if it is related (we have had sub zero weather here over the past week so it may well be battery related).
Did you determine this fault using IID tool or is that a screen grab your dealer gave you?
Cheers Current: MY22 P400e SE
Post #1054505 12th Dec 2024 3:47pm
Brulz
Italy
Both....
IID Tool report same DTC...
DTC Confirmed from Topix and diagnostic routine specific for DTC P0A7F-00
P400e purchased on October 2021.
km 68.000 (about 25.000km in EV mode / 43.000 Hybrid)
Battery cycle 100%-0%-100% about 1.500
Heath of battery:
Power lost: 19%
Capacity lost: 9,5%
The DTC Issue is not (maybe) related to Heath of battery...
19% and 9,5% is not so bad...
maybe the problem is locater in other parameters..
Post #1054506 12th Dec 2024 4:04pm
Ritson
France
Eerily similar. mine was purchased Sept 21 and has done 67k km but I would say majority of that using battery.
I will ask them to give me the same health report on the battery!!! I presume if I ask them to run the same diagnostic based on the fault code you mentioned I'll get a similar health report? Current: MY22 P400e SE
Post #1054508 12th Dec 2024 4:13pm
Brulz
Italy
Heath of battery is a BECM Module Application.
the dealer can do it also without DTC pending...
Post #1054527 12th Dec 2024 10:07pm
