Home > Tdi > oil drops out of air filter housing |
gbenson Member Since: 20 Aug 2024 Location: Dorset Posts: 5 |
Hi,
I know it’s been a while and you’ve probably solved it by now, but yes your suspicions are correct and it is the fault of the breather. They clog up and don’t work as effectively after a long time in use. You could try cleaning it out periodically but luckily they are pretty cheap to replace, when you do make sure to clean out the pipes to the air filter housing and replace the filter to stop any more oil getting in and ruining a new air filter. 1982 s3 2.25D “Shrödy” 1988 110 200tdi “Dave” Life is in fact a highway |
20th Aug 2024 10:38pm |
shaynecm Member Since: 10 May 2024 Location: Norwich Posts: 62 |
hi
i would look at the Alisport breathers as they have baffels in rather than the basic gauze in the cheapy land rover ones - will work klonger/better. |
21st Aug 2024 2:55pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17206 |
Fit a catch can such as a Provent to the breather line.
21st Aug 2024 3:24pm |
hydraulic_landy Member Since: 21 Dec 2021 Location: Bavaria Posts: 9 |
My current solution:
I have connected a new breather for the TDI200 engine and additionally a breather from the Freelander in series. Now the air filter is free of oil. I am aware that this does not eliminate the cause, but it helps.
24th Aug 2024 4:17pm |
