Home > Puma (Tdci) > Alarm Immobiliser |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 808 |
Hi
I had a problem with a 10AS module fitted to a TD5 a few years ago. I removed it and sent it to the chap below for reprograming / repair. I think that it cost £75 including refurbishment of the blipper fobs. https://www.technozen-electronics.co.uk/la...-services/ Drop him a line explaining the symptoms. Jim |
20th Aug 2024 10:53am |
audi1boy Member Since: 11 Dec 2020 Location: Somerset Posts: 24 |
Thanks Jim. I will ask the question. I have the later immobiliser I think which is a black box rather than the 10AS.
20th Aug 2024 10:56am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2079 |
You will have the later ALM module. It’s likely that you have the DHxxxxxxxxx serial number version, however you may have the earlier ALM CHxxxxxx Version. If you have the CH version it can suffer from a brownout issue if the starter battery is allowed to slowly drain to low volts, this causes some of the ALM software to be corrupted.
Best have a chat with remotekey https://www.remotekey.co.uk/shop/land-rove...trol-ecus/ You can see what unit you have by removing the drivers footwell speaker and looking up. |
20th Aug 2024 11:56am |
