Home > Maintenance & Modifications > CV Swivels Maintenance |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20418 |
I’d avoid Britpart, regards the rest of your questions I’d have a look on Ashcroft Transmissions web site and possibly ask them. $W33T $0U7H3RN $UG4R
14th Aug 2024 5:53pm |
PoormansXS Member Since: 21 Oct 2023 Location: Lincolnshire Posts: 49 |
If there is no bearing play and the balls are fine just pull the whole assembly off the axle and replace the large seal around the ball, the driveshaft seal, axle gasket and retainer plate.Think they all leak abit anyway.
As for seals get corteco and for bearings always timken. IIRC LR parts do a kit with everything minus the ball for £60 or so if you are going to do the lot EDIT: you won’t be replacing the driveshaft seal if you do it this way cause you won’t be taking the driveshaft out 🤣 So Corteco swivel seal Retainer plate Swivel ball to axle gasket Fresh 1 shot grease (1 sachet per side) Click image to enlarge |
14th Aug 2024 5:54pm |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 456 |
Thanks both, that is very helpful.
I'll have a look. Cheers. |
14th Aug 2024 6:08pm |
I think maybe me or Custom90 has you slightly misunderstood. I wouldn’t be talking to Ashcrofts unless you’re after new CV joints or driveshafts.
Also. Maybe consider replacing your brake caliper bolts and make sure your socket is fully home on the bolt when you take it out. Otherwise it’s a right ballache. Ask me how I know. You also need 12 point (bihex) 13mm socket for those. Click image to enlarge Click image to enlarge |
14th Aug 2024 6:19pm |
Yep thanks. Looked on Ashcroft but they only seem to do the full sets with CVs. I’ll look for your suggestions individually.
14th Aug 2024 9:31pm |
This but with corteco seals
https://www.ebay.co.uk/itm/291670421498?mk...media=COPY |
14th Aug 2024 9:36pm |
Just the job, thank you.
14th Aug 2024 9:55pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 623 |
Buy 2x Britpart RRY500180SS - stainless steel swivel retainers - not all Britpart needs avoiding |
19th Aug 2024 12:47am |
