![]() | Home > Puma (Tdci) > North Wales - Galvanised Chassis Rebuild + Overhaul |
Alun Member Since: 22 Dec 2015 Location: Snowdonia Posts: 47 ![]() ![]() ![]() |
I'm looking for some advice/recommendations please
I have a 2011 Defender 2.4. I want to have the chassis replaced with a galvanised one and then some work done on the engine to fix any of the (usual) small oil leaks and add in some soundproofing behind the dash and bonnet at the same time. Any personal recommendations? I've tried Mills 4x4 and they don't do chassis replacement work. |
landiedave Member Since: 14 Mar 2013 Location: Welsh Marches Posts: 58 ![]() ![]() ![]() |
You could try Williams Classics, they will do the job but might be a bit pricey.
Unit 1, Jacksonville Farm, Towyn Way W, Abergele LL22 9LG |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8221 ![]() ![]() ![]() |
Not north but try Cambrian 4x4 poc Chris Bowler. Top man, knows his stuff. Cheers
Thanks for the great suggestions, I'll follow those up
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5117 ![]() ![]() ![]() |
Mon 4x4 Anglesey
Unit 10/Pentraeth Ind Est, Pentraeth LL75 8LJ 01248 450002 Competent Independent Land Rover Garage, honest and trustworthy. This guy knows all there is about Land Rovers. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
V8Simon Member Since: 17 May 2016 Location: Prestatyn, Wales Posts: 150 ![]() ![]() ![]() |
Depends where you are but I'd recommend these guys. They do all sorts of LR work and seen them do a chassis swap on Discos as well as lots of work on my 90.
https://www.rhydymwynservicestation.co.uk/landrover-specialists/ 1984 90 V8 puma want to be. |
Beco90 Member Since: 10 Jul 2024 Location: South Wales Posts: 21 ![]() ![]() |
I’m a bit late to the party but you could try Apollo Automotive near Derwen. They do chassis swaps. Again have a look at their website and social media and see what you think:
https://www.apolloautomotive.co.uk/ |
Hi Alun - did you get the new chassis? I'm now looking and would be good to know how you got on.
Hi, I didn't in the end. Because of the space that it takes to have a vehicle AND a chassis in the shop at the same time, its a very small group of garages that can manage it, at least that's what I found when I tried and researched.
In the end, I'm booked in to get mine "ice blasted" with the axles done separately and then painted with Kent paint. Should be done by April and I'll happily give feedback then. The whole project took on legs and I've gone for a BMW 330D engine and suspension upgrade at the same time ![]() |
ooh, ice blasting - look forward to the feedback and pictures!
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 934 ![]() ![]() ![]() |
Alun, sounds like you’ve gone to Mahker? 2008 2.4 110 Utility Station Wagon XS.
Yes I did BrickBox, good deduction
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Unfortunately (for my bank balance!) the chassis was better to have another used one then repair the old one but the ice-blasting looks really good. I've not picked up my Defender yet but looking forward to seeing how the M57 performs ![]() |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 771 ![]() |
So it’s been rebuilt on a used chassis?
