Home > In Car Electronics (L663) > Adding SIM card option to Front AVIO Module
awktm
Australia
So I purchased a new AVIO module with SIM card so I could use my own data plan for the wifi hotspot I turned on.
I have set:
MultiCAN-468 FrontAVIOPanel
Current: Mid Line Fitted (USB with
OTG only)
New: Mid Line Fitted with SIM (USB with OTG, and SIM)
MultiCAN-812 PIVI SIM Type
Current: Machine-to-Machine eSIM
New: PSIM
I was wondering if some who has the SIM card option from the factory if these settings are correct?
I seem to register a fault which I think may be related as below:
ICCM-Infotainment Compute Con...
B14B6-93 (2F) USB Port #1 - no operation
I also see the option of a Highline with may be the correct option?
High Line Fitted with SIM
Mid Line Fitted (USB with OTG only) ***my factory selected option without sim***
The only other setting I imagine may need tweaking is:
MultiCAN-901 Front Connect Socket
Mid Line Fitted (Dual USB with H2H only)
Hoping someone can help? Thanks
Post #1042114 7th Aug 2024 11:34am
alamri666
United Arab Emirates
I did same I change to with sim and PSIM and not working. It seem like the TCU not connecting.
Post #1043355 20th Aug 2024 8:52pm
kenl
Australia
Have you tried turning off the Hotspot for a while, maybe it needs that to disconnect from the eSim? MY23.5 SE Defender
Post #1043383 20th Aug 2024 10:40pm
BadgerWaz
I've turned on the hotspot with my iid, and I connect via the defender to wifi and gain access to the internet, and without adding a sim card to the vehicle?
Aren't they all built like this?
MultiCAN-814 PIVI WiFi Hotspot
Internal WiFi Hotspot fitted
MultiCAN-817 IVle SIM Profile Type
Not Supported
Post #1043388 20th Aug 2024 11:27pm
kenl
Australia
I too have been thinking what to do post the eSim being supported (paid for) by Land Rover, I still have 18 months to go but after that I will be at the mercy of Land Rover and what ever they want to charge.
Unless we are given a way to access the eSim and use whatever provider we want.
I had not thought of using the phisical sim card holder, I think it was only used in the earlier models?
I do hope a solution is found! MY23.5 SE Defender
Post #1043422 21st Aug 2024 9:44am
