![]() | Home > Modifications & Maintenance (L663) > Electrochromatic Passenger Mirror Retrofit? |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3028 ![]() ![]() |
l am interested in this as well. l asked the question some time ago but received no response.
nebc100 Member Since: 07 Nov 2023 Location: Altlinster Posts: 99 ![]() ![]() |
Also interested!! Also asked, and didn’t get any answer 😁
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 311 ![]() ![]() |
If it were just buying the glass, knowing this would be very beneficial, good question! We look forward to hearing from someone knowledgeable.👍🏼👍🏼
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 174 ![]() ![]() |
Hi Guys,
It is definitely possible to upgrade the right/left Photochromic mirror, the wiring in the mirror is not there, but it is very simple, just add two wires that will go from the mirror to pins 13 and 14 of the connector under the internal lining. From this connector the wiring is already present. No coding is needed, everything works immediately, just be careful not to invert the two wiring wires. the connector is the small one with blue and purple wires. marco ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
That's great thank you for the information.
The_75th Member Since: 28 Apr 2023 Location: Devon Posts: 31 ![]() ![]() |
That looks great - so just need to find a LHD glass
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 140 ![]() ![]() |
Watching with interest would be great to add thr chromatic glass to the lh mirror as per my drivers side mirror. Don't know why it's not there from factory...
