Home > Maintenance & Modifications > Nugget replacement air filter cartridge
Page 6 of 6 <123456
Bluest
I believe I ordered the In Line Filters own brand equivalent, but the Alco is what came in the box. I can check the part number tomorrow.
I thought I had seen it in stock on Autodoc too. 2007 110 TDCi Station Wagon XS
Post #1041788 3rd Aug 2024 9:30pm
Jim_Bean
Thanks - I found it.
https://inlinefilters.co.uk/Filters-Air/Ca...N-FA14965/
Just ordered a couple. Thanks for the heads up Thumbs Up
Post #1041789 3rd Aug 2024 9:37pm
Bluest
This how mine came
Post #1041812 4th Aug 2024 11:43am
Ianh
Ianh wrote:
It looks like the NIPPARTS J1321017 is the correct dimensions .
Height [mm]:171
Inner Diameter [mm]:70
Diameter [mm]:127
Bore Ø [mm]:9
And has a soft seal at the top.
I purchased the NIPPARTS J1321017. Circa £18 delivered.
Externally the main body of the filter is exactly the same diameter and length as the original Wesfill WA830 filter. It also has the same metal mesh on the outside and inside of the filter as the Wesfil WA830. The filter material is red, unlike the Wesfil, however it looks like a quality filter.
For it to fit you do need to remove the thick rubber seal on the top ( it just peels off) and replace with some 10mm wide 4mm deep self adhesive ( one side) neoprene foam tape.
It’s then a perfect fit.
Edit - 2 weeks and several long high speed trips with engine under load and the filter has performed perfectly . No issues with vacuum gauge at all.
Post #1041989 5th Aug 2024 6:34pm
Page 6 of 6 <123456
