Home > Td5 > Master brake cylinder: Lucas 74471201 vs 74471207
CostaCosta
Costa Rica 2006 Defender 110 Td5 SW Alaska White
Dear friends. This is my first post here. Thanks in advance for your help. I am looking for the master brake cylinder for my Defender 110 TD5 and according to the information in the pump tank, the original part number is 74471201, Lucas. A local store is offering me the 74471207, Lucas too. What I found is the 74471207 is for Discovery 2. At the store, they told me it is the same, but I would like to have your feedback. I am not a mechanic, I only can say they look the same. Thanks
Defender TD5, 110, 2006, ABS, LHD
Regards.
Post #1040935 25th Jul 2024 6:40am
rallysteve
I believe the Land Rover part number you require is LR013017 (assuming LHD is the same as RHD as there is no differentiation on the parts diagram). Assuming those part numbers you are quoting are the Lucas numbers?
I am not sure if the physical master cylinder part of the Discovery 2 part is the same but they have totally different plastic reservoirs on top.
Post #1040954 25th Jul 2024 9:56am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Check for yourself here 👇🏻
https://www.lrworkshop.com/diagrams/land-r...-actuation 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1041038 26th Jul 2024 2:28pm
CostaCosta
Yes I did, but the part numbers are different. That confuses me too. The original is Lucas 74471201 and the one on those diagrams is LR013018, and the one at my local store is 74471201.
Thanks.
Post #1041059 26th Jul 2024 5:59pm
CostaCosta
Steve
Thanks Steve. You are right, plastic reservoirs are different.
Post #1041060 26th Jul 2024 6:18pm
