Home > Puma (Tdci) > Thank you
land 0068 japan
Japan 2007 Defender 110 Puma 2.4 USW Keswick Green
Thank you
Thank you
Post #1040955 25th Jul 2024 9:31am
andy63
Again I'm replying not through any practical experience as I've not had the pump off the engine but I would have thought the oil is normal and that's how the drive is lubricated.. The pump has two connections.. On the landrover one is normally blanked.. Is yours??
I did check the pump on mine and I'll check to see what it pulled👍
Post #1040961 25th Jul 2024 11:58am
andy63
It's pulling nearly a bar neg pressure👍
And you can see the brake pedal been depressed👍😂
Post #1040962 25th Jul 2024 12:24pm
