Home > Maintenance & Modifications > puma transmission upgrades |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2623 |
Thanks. Does Ashcroft not make stronger diffs for the Puma? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
4th Jan 2012 2:00pm |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2936 |
For not much more than the price of a4pin diff get a arb or ashcroft locker in there sorted
4th Jan 2012 2:22pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17192 |
Replacement front diff from LR (4-pinion since the 2-pinion is no longer sold for this application) collected from dealer: £1250. Replacement torque biasing front diff from Ashcroft c/w with heavy duty crownwheel & pinion including delivery etc: £888 Both prices are outright sales, if you return the old diff to Ashcroft you'll get £90 back. It really isn't a difficult decision! Ashcroft Transmissions can supply normal 4-pinion diffs, automatic torque biasing diffs (their own or Quaife), and full locking diffs (their own or ARB) for all wheelbases of Puma, either front or rear. All these are available with optional heavy-duty crownwheel and pinion sets, and you can have the diff pegged if you want too. Details on their website. I opted for the Ashcroft automatic torque biasing diff with HD crownwheel & pinion, for little more than half the price of a replacement open diff from Landrover. It was also nice to see engineer's blue on the teeth when it arrived, showing that the tooth engagement had been properly set up. Many Landrover diffs recently have not been at all well built! |
4th Jan 2012 3:20pm |
yeah, but shipping to RSA is a killer... -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
4th Jan 2012 3:22pm |
Sorry, I hadn't noticed your location!
4th Jan 2012 3:58pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2386 |
Detroit Trutrac is also a choice and good value. Puma 110" SW
4th Jan 2012 5:06pm |
Thing is, I don't necessarily want a TruTrac/Arb locker. I just want a standard diff that won't break in another 29,000km. Since I do mostly overlanding, if something goes wrong in the bush, it's easier to find a village workshop that knows the standard LR parts than some complicated aftermarket part. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
5th Jan 2012 9:16am |
Truetrac (is not a Detroit locker) is a very simple and strong bit for US$450. I agree, an ARB has some seals which can fail (unlikely) and costs the double. A std 4-pin LR would do the job for sure (what cost?).
Any how, why did the diff fail? Puma 110" SW ............................................................. Earth first. Other planets later |
5th Jan 2012 12:04pm |
It has not failed yet. Just the low-frequency drone you hear when you lift off which is the first symptom that it's on its way out. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
5th Jan 2012 12:06pm |
Perhaps a pinion-crown adjustment would save the diff. Puma 110" SW
5th Jan 2012 12:09pm |
sorgum Member Since: 24 Jul 2024 Location: Izmir Posts: 1 |
Click image to enlarge Completely manual, non-electronic automatic transmission conversion; Application of the 4HP22 automatic transmission, which also does not contain electronics, onto a 1988 model vehicle with a V184 engine that does not require an ECU. Defender Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Defender - Defender Parts |
24th Jul 2024 2:16pm |
