![]() | Home > Technical > 110 white smoke |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1151 ![]() ![]() ![]() |
Assuming then this is a 200 tdi? How many miles?
Excessive crank case venting normally means bore/ring wear resulting in combustion blow-by. Although not as straight forward as with petrol engine, but you can do a compression test to check for engine health. These engines are not that complicated and still quite common so you should be able to either overhaul or find a replacement engine. |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 910 ![]() ![]() ![]() |
I don’t have any experience with the Isuzu 4BD1, but I would start with cleaning the catch-can and replacing the PCV (if it has one?).
I would also check to see if oil is leaking on to the exhaust manifold. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
