![]() | Home > Puma (Tdci) > Wiper motor wrong direction. |
Sam smith Member Since: 12 Aug 2021 Location: Suffolk Posts: 63 ![]() ![]() ![]() |
Hi just put in my wiper motor but it is spinning the wrong direction, the park is working ok. What is the easiest fix?
Cheers |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 388 ![]() ![]() |
Never had mine apart so not 100% sure how they operate but thought it was a motor effectively moving a rack in the form of a long flexible coil within a tube that in turn rotates the drive spindles through a gear.
If that's the case and you have had the wheel box apart you have likely started the movement of the drive wheel180deg offset.. So you will need to open it up again and alter the start point by 180 deg.. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6560 ![]() ![]() ![]() |
New wiper motor or a refit of the old one?
If new what’s the part number ? ![]() ![]() |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2613 ![]() ![]() |
The change happened for the 2002 model year, early Td5s had the same setup as older vehicles.
The motor is the same, it is the drive gear that differs. As the wiper rack was moved from above to underneath the wheel boxes, the direction of movement was reversed. For RHD - on earlier (to 2001) vehicles the cable ‘pushes’ first. On later (2002-on) vehicles it ‘pulls’ first. |
