Home > Maintenance & Modifications > Future proofing a puma
SailingTom
My 110 dormobile is now on 150k mikes with some big trips planned m looking at some future proofing upgrades. I know you can always get caught out but it’s nice to try everything you can to prevent!
I should say it’s always waxoyld and serviced and maintained to a high standard, so far I’ve though and ordered;
Loff clutch and output shaft,
New injectors.
Thinking silicone hoses?
Anything else you guys had fail around that time or think could be worth doing extra to usual servicing and maintenance ? None of this is for massive off road expeditions, just driving good distances away from home adventuring.
Cheers Tom Defender puma dormobile camper
Post #1040574 21st Jul 2024 10:58am
bankz5152
Some high quality silicone hoses would be good. The rubber ones can delaminate and burst.
Personally I would swap out cooper brake lines for braided ones, pioneer do full kits. Not only does it make maintenance much easier but they wont corrode.
New bushes, would only fit genuine Land Rover (LR at the end not G) or SuperPro (my choice)
Apart from that all up to you!
Post #1040579 21st Jul 2024 11:54am
MK
If it is a 2.4, then carry a Genuine VCV.
Dedicated diagnostic tool.
Light switch or fit a relay. Puma 110" SW
Post #1040594 21st Jul 2024 2:27pm
SailingTom
Good suggestions guys thank you 🙏 Defender puma dormobile camper
Post #1040596 21st Jul 2024 2:38pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Fuel return o-rings/connectors on the injectors. Maybe even new washers on the injectors too.
Post #1040605 21st Jul 2024 3:32pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Another idea would be to replace the rear half-shafts with one-piece units. LOF sell these. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #1040778 23rd Jul 2024 7:39am
Dinnu
Front diffs are known to grenade on heavy Puma 110s. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1040794 23rd Jul 2024 10:21am
Zed
If you haven’t already I would consider fitting a catch can. WARNING.
Post #1040797 23rd Jul 2024 10:54am
This. If you have a two-gear diff in a Puma (which you probably do) it will fail, the only question is when.
Post #1040813 23rd Jul 2024 1:51pm
LR90XS2011
some recommend changing the cam chain and associated parts at about 150k DEFENDER 90 TDCI XS,
Post #1040863 24th Jul 2024 6:13am
keith
BW: what’s the symptoms and what’s your recommended replacement parts? I’m at 150k, just replaced the clutch and still got shocking bang and clunks from front drive.
Post #1040902 24th Jul 2024 2:28pm
keith wrote:
...BW: what’s the symptoms and what’s your recommended replacement parts? I’m at 150k, just replaced the clutch and still got shocking bang and clunks from front drive.
Well, shocking bang and clunks from front drive, for one. When mine failed the diff locked solid so it was the same effect as having a locked front locker, which is bad for steering. Since I was close to home and the roads were very wet I was able to drive home carefully. I have heard of others where the pinion and crownwheel have locked, locking the front axle solid, which is even worse.
If you suspect that your front diff is beginning to break up then firstly drain the oil and check for fragments, and secondly remove the filler plug and (with a torch) inspect as much as you can see through the hole. If you have a two-gear diff it should be possible by rotating the diff to see if the cross-pin is broken or misplaced. The usual failure mode for these diffs is that the cross-pin starts to rotate, elongates the hole in the diff carrier in which it sits allowing the differential gears to move around, and eventually the whole shebang fails, usually breaking the cross-pin and ejecting gears and teeth into other moving parts which then stop moving.
If the diff has failed but not locked you can also often feel clunking, roughness, and other alarming sensations if you rotate the propshaft with the front wheels raised.
Post #1040912 24th Jul 2024 5:18pm
keith
Thanks BW for your detailed and excellent explanation Thumbs Up
Post #1041307 29th Jul 2024 9:20pm
jst
I future proofed my 2.4 drive train with ashcroft locker front and rear, ashcroft shafts and drive members along with ashcroft cvs front. Went with a low pinion hypoid rear diff from ashcroft for best strength. That's all on a heavily loaded 130.
Swivels may need looking at along with bushes and a frame ball joint disc thickness would be worth checking and possibly stainless pistons for calipers if in there replacing parts anyway Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1041400 30th Jul 2024 5:17pm
