Home > Maintenance & Modifications > Front Side Lights only not working
Page 2 of 2 <12
Sybrow
United Kingdom 2011 Defender 90 Puma 2.4 X-Tech LE Zambezi Silver
In case it makes a difference: mine already has a dim dip dummy relay, which is located in the driver's fuse box
Post #1040276 18th Jul 2024 8:33pm
That could be it, it is 2 pole that’s for sure, mine was just up under the wing near the brake fluid.
But it might have been re-located.
Post #1040278 18th Jul 2024 8:40pm
Sybrow
Thumbs Up
I'll try it
Post #1040279 18th Jul 2024 8:41pm
Your vehicle does not have dim dip fitted (evidenced by the fact that your photos clearly show a headlight adjuster).
Post #1040290 18th Jul 2024 10:12pm
Sybrow
Thanks Blackwolf. I assumed that because the lower bulb in the headlight comes on as a sidelight. That meant it was dim dip.
Any ideas on why my sidelights aren't coming on?
Post #1040294 18th Jul 2024 10:51pm
Before you fitted the LED sidelights, did the old incandescent ones work? If so the most likely reason for the LED lights not working would be a polarity issue.
If the old lights also didn't work and you know that the bulbs were OK, then the rather janky wiring on your vehicle is likely to be the problem. Although not much is visible in your photos it does look a bit janky!
Do the (new) sidelights work if you plug the connector from the headlight lower bulb (the one that comes on with the sidelights) directly into the sidelight?
Finally can you confirm whether the headlights are LED units or not? I assume not since they have the sidelight bulb in them.
Post #1040323 19th Jul 2024 10:13am
Sybrow
Thanks Blackwolf
Current headlights aren't LED. I thought I had got the polarity the right way around, but will double check. Am away for a couple of weeks so will check asap.
I did try connecting the new side lights into the connector from the headlight lower bulb, but they still didn't work so may well be janky wiring!
Will respond back asap.
Post #1040634 21st Jul 2024 6:14pm
Page 2 of 2 <12
