Home > Technical > Swivel to axle bolts
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
How to folks torque the bolts that fit the swivel housing to the front axle? I cannot get a socket on there. Is the a special tool for this?
Post #1040042 15th Jul 2024 8:16pm
htb2
Wales
Never torqued them in 35 yrs, just done them up nice and tight with some thread lock on the bolts.
Post #1040047 15th Jul 2024 8:40pm
As above. Use common sense instead of a torque wrench.
Very few fasteners on a Defender need a torque wrench.
Post #1040049 15th Jul 2024 8:51pm
bankz5152
Spanner + few taps from a club hammer.
You could be anal and buy 12 sided crows foot spanners but iust isnt needed. Instagram @defender_ventures
Empire Tuning - Agent
Post #1040067 16th Jul 2024 5:24am
Dinnu
Actually you can use a regular spanner and a torque wrench at the same time. If you keep the spanner and the torque wrench perpendicular (90 degrees) to each other, the moments exerted by the torque wrench are exactly equal to the moments at the other end of the spanner. If not, the spanner will go spinning.
I use a double ring spanner for swivel bolts. 9/16” fits really nicely. Other end is 1/2” and could easily put a 1/2” extension nut and use a 1/2” socket on the torque wrench. But as others said, its not really required, so I just do them up by hand, roughly to the same force I needed to undo them… which probably is an over tightening Whistle 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1040069 16th Jul 2024 6:10am
Dinnu
Noticed you have a 2012 Defender. So just do the bolts. It is more likely that the complete flange falling off than the bolts failing Rolling with laughter
Apologies for the laugh. No pun intended.
Dont forget to fit the catch brackets again. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1040072 16th Jul 2024 6:23am
John P
Thanks for the replies. Actually this is for my other Defender which is a 110 2.4 2011, which has the friction weld . Thumbs Up
I'll just tighten them with an spanner with a "bump" of a dead hammer and some "blue" locktight.
Post #1040086 16th Jul 2024 10:29am
Ianh
A topic worth a read, same conclusion https://www.defender2.net/forum/post567244.html
Post #1040091 16th Jul 2024 11:42am
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
I made this tool.
It was prettier but the guy that welded it for me cooled it under cold water, subsequently it broke on the first try. I re-welded it and now it works perfectly.
I made it from an old 14mm spanner and a socket that I cut to length.
Use it at 90 degrees to the axis of the torque wrench.
Post #1040108 16th Jul 2024 5:36pm
landy andy
Sod that. A 14mm ratchet spanner Thumbs Up Thumbs Up
Post #1040125 16th Jul 2024 7:37pm
Dinnu
There are also what are called “Universal spanner adapter”, that kind of goes onto a spanner and provides a 1/2” drive so can fit a torque wrench on it. Google is your friend. As also mentioned, if the spanner and torque wrench are at 90degrees to each other, the torque setting set in the torque wrench is the final torque implied on the bolts. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1040205 18th Jul 2024 5:26am
John P
Everyday is a learning day. That "Universal spanner adapter” is a great idea. Just bought one to have in the tool kit. Thumbs Up
Post #1040236 18th Jul 2024 2:23pm
Ianh
And at circa £6.99 delivered from the bay of e it’s always handy to have
Post #1040273 18th Jul 2024 8:28pm
