Home > Technical > Defender won’t start
Pschinzel
United States
My 1992 defender 110 will not start.
A technician from Monarch defender states it could be a blown fuse.
Currently car will not power on radio, light bar, or window regulators.
I’ve replaced battery with new Interstate MTX H8.
The car is equipped with a Holly Sniper.
Could there be a fuse that could be impacting Holly Sniper that also would be affecting the other electrical items I’ve mentioned?
Thanks for any insights!
First post ever so if this is in incorrect channel please let me know.
Additionally, I’m not mechanically adept, therefore, I may be limited in my ability to solve this issue but wondering if there might be an easy fix.
Post #1039883 13th Jul 2024 9:14pm
Do you know what voltage the battery is sitting at rest?
There is the possibility of parasitic battery drain, I’m presuming you mean a kind of alarm or security device is fitted?
Battery clamps need to be tight and grounding points also secure, clean and tight enough.
These are some of the more basic issues, often the most common.
Was the battery fully charged also before you fitted it? It could be low, or need a charge to fill capacity first.
Hope some of these suggestions might be helpful. TheThunder Rolls🇬🇧🇺🇸
Post #1039902 14th Jul 2024 8:11am
donmacn
My car is a 1994 300Tdi, so not so different.
On holiday in France recently, we packed up camp, jumped into the car, turned the key and …… nothing. No clicks, nothing.
My hard-wired battery monitor was showing “low” and the radio was stuck in a loop of powering up, I’d switch it off, it would power up, I’d switch it off etc…. (suggesting an intermittent power connection). The multimeter on both batteries was showing 12.4v.
Then, after a few moments I tried again…. and it worked fine. It has worked fine every single time since then - about 3 or 4 weeks now. It had worked without a problem for many, many months before that.
I was completely confident that everything else was fine - wiring, batteries, fuel, starter etc.
So what? I had taken the steering cowling off a few days earlier to look at the wiper switch, and my best guess (which I haven’t looked at yet) is that one of the terminals at the back of the ignition was dislodged?? Maybe check out the connections at the back of the switch if someone’s been in there? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #1039903 14th Jul 2024 8:41am
Chicken Drumstick
Re: Defender won’t start
Are you saying there is no ignition? When you turn the key nothing lights on the dash?
The wiring is pretty simple on these. You’ll just have to follow the wiring and see where the issue is. Check for power at the fuse box then at different wires. I like to use a simple bulb tester but a multimeter would work too.
Can’t believe it is anything too untoward.
I can’t see how the Holley would cause this unless it was wired in badly and caused a short. Is it a new addition? Unless you are saying it is cranking and not firing….
Do you have an immobiliser fitted at all?
Post #1039909 14th Jul 2024 9:55am
