Home > Maintenance & Modifications > Bonnet letters refit after refurb…
Paddy Dakar
Wales 2007 Defender 110 Puma 2.4 HT Cairns Blue
Letters were removed with a little bit of heat and trim tool, scotchbrited, plastic primed then rattle can painted Matt black.
Before I removed, the letters were traced onto some 2 inch masking tape, for spacing.
Placed tape straight on cutting mat, lined up straight edge along bottom of letters.
Used more 2 inch tape on top to hold in place, then some clear application tape over all (layered 2inch tape would also work if you can’t get app tape)
Measured and marked centre line on letters, used 1 inch tape lined up with bottom of bonnet for guide, centre lined that also.
Lay the lot in position, hinge back,remove adhesive protection film, fold all into position and press each letter down.
Basic stuff, but might help someone 👍
Post #1039875 13th Jul 2024 7:55pm
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Thanks Paddy, will be doing something similar soon,
From the centre line whats the distance to the back of the D in LAND and then to the front of the R in ROVER
Very Happy
Shane
Post #1040000 15th Jul 2024 11:35am
Paddy Dakar
Hi Shane,
If you look at the pic above with my measuring tape the centre line is at the 330mm point which is also the start of the R in rover and the other measurement you were looking for is at the 215mm mark which is 115mm away from centre line (330-215=115) 👍
I’ve enlarged it below for you!
Post #1040020 15th Jul 2024 3:08pm
Zed
Nice work mate. WARNING.
Post #1040027 15th Jul 2024 6:42pm
shanecl
Paddy Dakar wrote:
Hi Shane,
Perfect, Thanks Paddy Very Happy
Post #1040079 16th Jul 2024 10:20am
